Is it possible to change automation variables from a separate script?
I have an automation that is created from a blueprint. I want to be able to change the variables of the created automation by running a script but I can’t seem to find how to reference the variables in a home assistant script. Here is my blueprint:
blueprint:
  name: Sprinkler Automation v2025.05.23.02
  description: Another attempt at sprinkler automation
  domain: automation
  input:
    switch:
      description: The boolean of the sprinkler switch to toggle ON or OFF
      selector:
        entity:
          domain: switch
    start_time_1:
      name: Start Time - First Pass
      description: Time of Day to turn ON the sprinkler
      selector:
        time:
    stop_time_1:
      name: Stop Time - First Pass
      description: Time of Day to turn OFF the sprinkler
      selector:
        time:
    start_time_2:
      name: Start Time - Second Pass
      selector:
        time:
    stop_time_2:
      name: Stop Time - Second Pass
      selector:
        time:
variables:
  start_time_1: !input start_time_1
  stop_time_1: !input stop_time_1
  start_time_2: !input start_time_2
  stop_time_2: !input stop_time_2
mode: single
triggers:
  - trigger: time
    at:
      - !input start_time_1
      - !input stop_time_1
      - !input start_time_2
      - !input stop_time_2
  - trigger: homeassistant
    event: start
conditions: []
actions:
  - choose:
      - conditions:
          - condition: time
            after: !input start_time_1
            before: !input stop_time_1
          - condition: time
            after: !input start_time_2
            before: !input stop_time_2
        sequence:
          - data: {}
              entity_id:
                - !input switch
            action: switch.turn_on
    default:
      - data: {}
          entity_id:
            - !input switch
        action: switch.turn_off
Hello slam121212,
You cannot change variables in an automation or automation blueprint on the fly directly. You can have input helpers referenced in the variables and change the value of those.
You can change the variables that are loaded into scripts or script blueprints by pulling them in with fields. and calling the script with a data key.
For example one of my blueprints…
HA_Blueprints/Scripts/play_media_file_script.md at 2c8a5d942a24a4f00611f4d04f9ca6cb0832508c · SirGoodenough/HA_Blueprints · GitHub.
Yeah thats what I was afraid of. Is there a way to “bundle” input helpers into a custom object? I have about 10 automations to make. With each having 4 variables, that’s 40 helpers which is a pain to change/edit later one by one
