Hello, I would like to create a view where everyone can go and, if necessary, adjust the setpoint temperature of the different rooms.
The problem is that if I use a card like the “Scheduler Card,” even if I create a new card each time, it seems that all the cards are linked. If I change the variable or the time on one card, it also changes on all the other cards in the overall view.
My goal was to have one card per room… but I don’t understand why they are linked, since I’m not making duplicates.
A schedule is like a crate in the crate you have put 21 apples.
Each apple represent a degree in your thermostat.
If you tell 5 people to go look into to the box they will all see 21 apples and if one person remove an apple, then all will see 20 apples.
If you want the system to be more diverse, then you need to expand the system.
You can either put up 5 boxes with each a set of apples (= make more schedules) or you can divide the box into areas, where each person look at a specific area (= put a tag in the schedule).
