Is it possible to install hassbian scripts on raspbian install?
I just received my pi4 so I installed hass using the manual install process on raspbian buster.
Working fine so far. But my current pi3 hass was installed using hassbian and I am used to using the scripts. Is it possible to install the scripts on raspbian essentially converting it to hassbian? I sort of remember reading somewhere that hassbian was basically raspbian with the scripts pre-installed. However, I can’t seem to find installation instructions anywhere.
As long as you’ve set it up the same way as Hassbian (same venv location, same username, etc) then yes you can.
The docs for it no longer say how you’d do that though, so I’d swing by the #hassbian channel of the Discord server and ask there.
Thanks, good idea. I did setup things same as hassbian so might workout.
