I would like to migrate my Zigbee2MQTT Zigbee network from SONOFF Zigbee 3.0 USB Dongle Plus (ZBDongle-P with chipset: TI CC2652P + CP2102(N)) to a Nabu Casa ZBT-2 that I recently bought. (I want to continue using Zigbee2MQTT -- so not switch to ZHA)
I want to migrate my Zigbee network without re-pairing, because it has 85 devices and would require much effort.
I tried following these instructions to migrate: FAQ | Zigbee2MQTT
I know these are different stack (zstack vs. ember), but found the following statement here that it might work:
When switching from zstack -> ember or ember -> zstack re-pairing might not be required, however results might vary as this is not officially supported.
However, I get this error after switching my Z2M configuration to Nabu Casa ZBT-2 with ember stack:
[2026-05-24 00:32:14] e[31merrore[39m: z2m: Error while starting zigbee-herdsman
[2026-05-24 00:32:14] e[31merrore[39m: z2m: Failed to start zigbee-herdsman
[2026-05-24 00:32:14] e[31merrore[39m: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2026-05-24 00:32:14] e[31merrore[39m: z2m: Exiting...
[2026-05-24 00:32:14] e[31merrore[39m: z2m: Error: [BACKUP] Current backup file is not for EmberZNet stack.
at EmberAdapter.getStoredBackup (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1154:23)
at EmberAdapter.initTrustCenter (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:925:29)
at processTicksAndRejections (node:internal/process/task_queues:103:5)
at runNextTicks (node:internal/process/task_queues:68:3)
at processImmediate (node:internal/timers:452:9)
at EmberAdapter.initEzsp (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:708:18)
at EmberAdapter.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1538:24)
at Controller.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/controller/controller.ts:146:29)
at Zigbee.start (/app/lib/zigbee.ts:70:27)
at Controller.start (/app/lib/controller.ts:111:29)
Am I out of luck or is there some "trick" that I might try?
