Is it possible to run scripts according to a template?
I have this code in an automation, and need to know if this is possible at all, running one or more scripts this way??
    - service: homeassistant.turn_on
      data_template:
        entity_id: >
          {% if is_state('device_tracker.pal_presence', 'Away') and
          is_state('device_tracker.eva_presence', 'Away') %}
            script.espresso_turn_off
          {% endif %}
You don’t have an else statement. That’s going to generate errors.
Also you would be better off with a service template rather than a data template (scripts are services):
    - service_template:
        {% if is_state('device_tracker.pal_presence', 'Away') and is_state('device_tracker.eva_presence', 'Away') %}
        {% else %}
          ## another service here
        {% endif %}
Thank you for your clear eyes and suggestion, @tom_l :slight_smile:
@tom_l: Will I be able to list several scripts in a row like this?
    - service_template:
          - script.espresso_turn_off
          - script.another_script
          - script.a_third_script
          - service.even_a_service_to_run
        {% else %}
        {% endif %}
No. Only one.
If you need to do that, create one big script.
Thank you!
