I’m tired of renewing my tokens and get a non working home every once in a while. Really, that’s super not cool.
Is there any decent way to get my Tuya devices in sync with HA without being dependant on Tuya IoT services tokens?
Hi hAtul, you are probably after the custom integration LocalTuya
Is it a bit of an hassle to get the local key from the Tuta IoT platform, but follow these instructions and you are on the go.
I tried doing this and… I cannot get the local key of my devices since they are isolated on a “Guest” network.
Any other way to get that local key other than this method/disassembling a wall switch? @ha_karel
I have seen a method to get the local key using an rooted android device, but as i do not have any andriod os available i didn’t find any other option than to go with the IoT platform.
To make this happen I activated internet access in my IoT VLAN, which is offline by default, and I went through the process to get the local key.
