Is it still possible to connect nest?
Ive been trying to set up my nest integration for hours. I got as far as adding in the project info and now I’m getting the following error. How do I resolve this?
home-assistant.io has not completed the Google verification process. The app is currently being tested, and can only be accessed by developer-approved testers. If you think you should have access, contact the developer.
Did you manage to get this resolved? I’m having the same issue and its the first device I’m trying to add to Home Assistant so not sure if I’ve messed something up.
