Hi!
I have CC2531 USB stick what is flashed with CC2531_DEFAULT_20190608.zip
Stick is connected to Raspberry Pi 4 where hass.io ver: 192 is running.
I have: # Zigbee2mqtt Hass.io Add-on 1.6.0
Config:
"data_path": "/share/zigbee2mqtt",
"devices": "devices.yaml",
"groups": "groups.yaml",
"homeassistant": true,
"permit_join": true,
"mqtt": {
"base_topic": "zigbee2mqtt",
"server": "mqtt://a0d7b954-mqtt",
"user": "mqtt",
"password": "mqtt"
"serial": {
"port": "/dev/ttyACM0"
"advanced": {
"pan_id": 6754,
"channel": 11,
"network_key": [
1,
3,
5,
7,
9,
11,
13,
15,
0,
2,
4,
6,
8,
10,
12,
13
"availability_blacklist": []
"ban": [],
"whitelist": [],
"queue": {},
"socat": {
"enabled": false,
"master": "pty,raw,echo=0,link=/dev/ttyZ2M,mode=777",
"slave": "tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5",
"restartdelay": 1,
"initialdelay": 1,
"options": "-d -d",
"log": false
Log file says:
./run.sh: line 16: [Info] Configuration backup found in /share/zigbee2mqtt/.configuration.yaml.bk. Skipping config backup.: No such file or directory
[Info] Socat is DISABLED and not started
2019-11-10T12:37:38: PM2 log: Launching in no daemon mode
2019-11-10T12:37:38: PM2 log: App [npm:0] starting in -fork mode-
2019-11-10T12:37:38: PM2 log: App [npm:0] online
> [email protected] start /zigbee2mqtt-1.6.0
> node index.js
zigbee2mqtt:info 11/10/2019, 12:37:41 PM Logging to directory: '/share/zigbee2mqtt/log/2019-11-10.12-37-41'
zigbee2mqtt:info 11/10/2019, 12:37:42 PM Starting zigbee2mqtt version 1.6.0 (commit #unknown)
zigbee2mqtt:info 11/10/2019, 12:37:42 PM Starting zigbee-shepherd
zigbee2mqtt:info 11/10/2019, 12:37:43 PM zigbee-shepherd started
zigbee2mqtt:info 11/10/2019, 12:37:43 PM Coordinator firmware version: '20190608'
zigbee2mqtt:info 11/10/2019, 12:37:43 PM Currently 0 devices are joined:
zigbee2mqtt:warn 11/10/2019, 12:37:43 PM `permit_join` set to `true` in configuration.yaml.
zigbee2mqtt:warn 11/10/2019, 12:37:43 PM Allowing new devices to join.
zigbee2mqtt:warn 11/10/2019, 12:37:43 PM Set `permit_join` to `false` once you joined all devices.
zigbee2mqtt:info 11/10/2019, 12:37:43 PM Zigbee: allowing new devices to join.
zigbee2mqtt:info 11/10/2019, 12:37:43 PM Connecting to MQTT server at mqtt://a0d7b954-mqtt
zigbee2mqtt:info 11/10/2019, 12:37:43 PM zigbee-shepherd ready
zigbee2mqtt:info 11/10/2019, 12:37:43 PM Connected to MQTT server
zigbee2mqtt:info 11/10/2019, 12:37:43 PM MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
zigbee2mqtt:info 11/10/2019, 12:37:43 PM MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"version":"1.6.0","commit":"unknown","coordinator":20190608,"log_level":"info","permit_join":true}'
zigbee2mqtt:info 11/10/2019, 12:40:23 PM Successfully reenabled joining
zigbee2mqtt:info 11/10/2019, 12:43:03 PM Successfully reenabled joining
Green led on the stick is constantly burning.
I have tried to join multiple different devices, but I cannot get any other lines to log file… No errors and no any pairing lines like:
Successfully interviewed ‘0x00158d0001dc126a’, device has successfully been paired
I have also tried to use https://github.com/Frans-Willem/AqaraHub and no success.
So… is my USB stick faulty? (from aliexpress)
Can I some way to do “debug” of the stick?
