Hello, is possible to run HA on https when port 443 is already open? Because I don’t think so. I am trying for hours and I am so tired and lost how complicated this is.
My main machine is 192.168.0.110 here is nginx running.
My HA is HAOS running on KVM (192.168.0.73) on that main/host machine.
Port 80 and 443 are open for 192.168.0.110.
My nginx reverse proxy:
server {
if ($host = domain.xyz) {
return 301 https://$host$request_uri;
}listen 80; server_name domain.xyz; return 301 https://$host$request_uri;
server {
ssl_certificate /etc/letsencrypt/live/domain.xyz/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/domain.xyz/privkey.pem;location / { proxy_pass http://192.168.0.73:8123; proxy_http_version 1.1; proxy_set_header Upgrade $http_upgrade; proxy_set_header Connection 'upgrade'; proxy_set_header Host $host; proxy_cache_bypass $http_upgrade; } listen 443 ssl;
My HA configuration is:
http:
use_x_forwarded_for: true
trusted_proxies: 192.168.0.110
Atm when I go to https://domain.xyz it says SSL is OK, but I am getting 502 Bad Gateway.
Can somebody help me with it please?
