Is Synology DSM5 not supported anymore?
Since a few days my Synology DS410 (running on DSM5) is not working properly anymore, but it worked well before. When I try to re-add it, it looks like the API is not returning the expected answers. I tried a lot: disable 2TFA, create a new user, etc … but since it worked before, I don’t know where to look.
I am running 2025.2.2
Btw: I also have a Synology DS214+, that is running ok.
This is in the homeassistant.log
2025-02-11 15:25:58.273 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry DiskStation for synology_dsm
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 637, in __async_setup_with_context
    result = await component.async_setup_entry(hass, self)
  File "/usr/src/homeassistant/homeassistant/components/synology_dsm/__init__.py", line 75, in async_setup_entry
    await api.async_setup()
  File "/usr/src/homeassistant/homeassistant/components/synology_dsm/common.py", line 168, in async_setup
    shares = await self.dsm.file.get_shared_folders(only_writable=True)
  File "/usr/local/lib/python3.13/site-packages/synology_dsm/api/file_station/__init__.py", line 57, in get_shared_folders
    additional = folder["additional"]
KeyError: 'additional'
2025-02-11 15:26:56.612 ERROR (MainThread) [aiohttp.server] Error handling request from 172.24.0.2
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py", line 480, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py", line 569, in _handle
    return await handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py", line 117, in impl
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 210, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 86, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
    response = await handler(request)
  File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin
    return await func(self, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 222, in post
    return await super().post(request, flow_id)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper
    return await method(view, request, data, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 121, in post
    result = await self._flow_mgr.async_configure(flow_id, data)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 340, in async_configure
    result = await self._async_configure(flow_id, user_input)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 387, in _async_configure
    result = await self._async_handle_step(
        flow, cur_step["step_id"], user_input
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 490, in _async_handle_step
    result: _FlowResultT = await getattr(flow, method)(user_input)
  File "/usr/src/homeassistant/homeassistant/components/synology_dsm/config_flow.py", line 356, in async_step_link
    return await self.async_validate_input_create_entry(user_input, step_id=step)
  File "/usr/src/homeassistant/homeassistant/components/synology_dsm/config_flow.py", line 230, in async_validate_input_create_entry
    self.shares = await api.file.get_shared_folders(only_writable=True)
Hmmm, I just found out when I downgrade to 2025.1.4 it is working.
Uh, now what?
Maybe you can speedup getting a fix for this Problem by helping here.
GitHub
Unfortunately i don’t understand how to deal with VSCode, etc.
