I’m using this automation to turn on and off two lights based on whether Sleep mode is active or not. Is there a better way to do this?
And also the code confuses me
After choose: we have conditions: and then condition “off” , but then why do we have conditions again? right before condition: on? Shouldn’t there be a single conditions: list
why is the sequence keyword at the same indentation level as conditions? Shouldn’t it be at a lower indentation level than condition: “off”
Not sure I got this correct but I guess you can use variables.
alias: Bedroom motion activated lights with state
description: >-
Turn lights on when Motion detected in bedroom.
triggers:
- entity_id:
- binary_sensor.ikea_of_sweden_tradfri_motion_sensor_motion
to: "on"
trigger: state
variables:
bedroom_light: "{{ 'on' if states('input_boolean.sleep') == 'off' else 'off' }}"
wait: "{{ 5 if states('input_boolean.sleep') == 'off' else 0 }}"
conditions: []
actions:
- action: "light.turn_{{ bedroom_light }}"
metadata: {}
data: {}
label_id: bedroom_light
- action: switch.turn_on
metadata: {}
data: {}
label_id: bedroom_night_light
- wait_for_trigger:
- entity_id:
to: "off"
trigger: state
- delay:
hours: 0
minutes: 0
seconds: "{{ wait |int }}"
- action: light.turn_off
metadata: {}
data: {}
- action: switch.turn_off
metadata: {}
data: {}
mode: single
I guess they could be used in the actual code also but it might looks better like this in my opinion.
The idea with the bedroom is that if asleep then it does a off command, waits then off again.
You could us a if/then only on that light… but a off command wont hurt
Yeah, that seems like a good solution. I haven’t dived into jinja templates yet, looks kinda complicated.
And I guess I’ll have to use another variable if I wanted to change the light properties as well.
I don’t see the wait variable being used anywhere, was that supposed to be referenced somewhere else?
I tried using variables in the developer tools and if one is not set then {{ a or b }} does seem to work. If both is set then it sems to use a.
Perhaps it’s different in automations.
description: >-
triggers:
- entity_id:
to: "on"
trigger: state
variables:
- entity_id:
to: "off"
for:
seconds: 5
trigger: state
conditions: []
actions:
- action: "light.turn_{{ trigger.to_state.state or bedroom_light }}"
metadata: {}
data: {}
- action: "switch.turn_{{ trigger.to_state.state }}"
metadata: {}
data: {}
mode: single
So now I moved the wait to the trigger using for:.
Maybe this does not work as expected. You need to test it.
I have not even looked at the script or anything. But, do want to try to explain the choose syntax that you questioned.
Choose allows multiple paths based on specific conditions. Each condition for a choose can actually be multiple conditions. Meaning for each path, you need to be able to provide a list of conditions.
Conditions, by default, are and. So, if you have a list under conditions of more than one, they all must be true for it to be true. If you need them to be or, you can make your first condition in the list an or condition with a list of the conditions you need to be ored.
That is just a brief primer (although probably confusing) on conditions. Better info at that link.
Now, back to choose …
Each path the choose can take is identified by a list of conditions. The sequence goes with each conditions statement.
actions:
- choose:
- conditions: * Path 1
- condition: state * Single condition for Path 1
entity_id: input_boolean.sleep
state: "off"
sequence: * Sequence for Path 1
- action: blah
- conditions: * Path 2
- condition: state * And conditions for Path 2
entity_id: input_boolean.sleep2
state: "off"
- condition: state
entity_id: input_boolean.sleep3
state: "off"
sequence: * Sequence for Path 2
- action: blah
- conditions: * Path 3
- condition: or * Or conditions for Path 3
conditions: * Another list of conditions for the Or
- condition: state
state: "off"
- condition: state
state: "off"
sequence: * Sequence for Path 3
- action: blah
I hope this actually helps and does not make everything more confusing.
