Is there a simple time range switch where you can add multiple time ranges? I would like up to 4 different time ranges in one switch if it exists.
I’m also interested in this. Would clean up my flows a lot
node-red-contrib-timerswitch
Timerswitch is just acting on different times … but not a select based on different times.
I just use several switch nodes for the different time ranges …this is as well helping the debugging
I would just stack several timerange nodes and wire the preceeding node to all of them. Could also be convenient when it comes to troubleshooting.
This is basically what I do
That’s what I’v been doing.
Just turned it into a subflow instead now.
