Is there a way to create a group of buttons of which only one can be active (selector, etc)
I can create a button that changes based upon a condition, but I’m trying to figure out how to create a group of buttons that act like a radio button input on a form.
If I press A, it lights up, if I press B, A turns off and B lights up…and so on, all to control selection of items in an input_select.
Never mind. I figured it out.
If you have an input_select entity defined, you can use a button to call a tap_action using the input_select.select_option service, targeting the appropriate entity to change. Here’s my yaml:
- type: custom:button-card
    entity: input_select.season
    color_type: card
    color: rgba(0,0,0,0%)
    show_state: true
    tap_action:
      action: call-service
      service: input_select.select_option
        entity_id:
          - input_select.season
        option: Winter
    state:
      - value: Winter
        color: green
    color_type: card
    show_state: true
    tap_action:
        entity_id:
        option: Summer
    state:
      - value: Summer
        color: green
    color_type: card
    show_state: true
    tap_action:
        entity_id:
        option: Fall
    state:
      - value: Fall
        color: green
    color_type: card
    show_state: true
    tap_action:
        entity_id:
        option: Spring
    state:
      - value: Spring
        color: green
This uses button card in HACS.
