Is there a way to manually edit the network info?
First off I’ll say, I’m completely new to HASS.
I’ve installed it on a Synology VMM using the OVA method. It installed without issue, however mounting a USB to a VMM is rather painful (and there doesn’t seem to be a way to re-direct a storage folder to the VM as a “USB” device.
The only thing I’d like to edit is my networking info. I dont understand why this is so difficult to do (why is there no interface for this?).
I’ve found the file editor add-on, and I’ve tried the terminal, but it seems that the entire networking stack is hidden/blocked from editing.
Is there no way to manually edit the network info?
Found the answer to my own question…
Login to your HA > Supervisor > System > Host (click Change besides IP Address).
