How do I use a service_template / data_template to do dynamic attributes? For example, I have a remote that, when a button is pushed, it turns off the lights. Whereas another button would dim the lights.
- alias: "Cube Controller"
hide_entity: false
- platform: state
entity_id: sensor.cube_controller
condition:
condition: and
conditions:
- condition: template
value_template: "{% if is_state('sensor.cube_controller', 'inactive') %}false{% else %}true{% endif %}"
- service_template: "{% if trigger.to_state.state == 'Knock' %}light.turn_off{% else %}light.turn_on{% endif %}"
data_template:
entity_id: >
{% if trigger.to_state.state == 'Rotate left' or trigger.to_state.state == 'Rotate right' %}
light.office
{% else %}
light.office
{% endif %}
brightness: >
{% if states.light.office.attributes.brightness is defined %}
{% if trigger.to_state.state == 'Rotate left' %}
{% if states.light.office.attributes.brightness|int - 75 <= 0 %}
5
{% else %}
{{ states.light.office.attributes.brightness|int - 75 }}
{% endif %}
{% elif trigger.to_state.state == 'Rotate right' %}
{% if states.light.office.attributes.brightness|int + 75 >= 255 %}
255
{% else %}
{{ states.light.office.attributes.brightness|int + 75 }}
{% endif %}
{% endif %}
{% else %}
5
{% endif %}
- delay: 00:00:01
- service: mqtt.publish
topic: 'smartthings/Cube Control/button'
payload: 'inactive'
retain: 'true'
This is all well and good, but if I have a service_template that does ‘light.turn_off’, well, it doesn’t like the ‘brightness’ configuration being there.
