Is there a way to uniquely identify rtl_433 devices to avoid duplicates?
Not know if I am asking for something which is impossible to do, but let me try.
I got and installed RTL-SDR Blog R820T2 RTL2832U to detect data from 433Mhz, 915Mhz devices. Installed 433_rtl and 433_auto_discovery and everything seems to be working.
Here is my observation - if a 433mhz device is turned off, leaves the reception area, or the HaOS is rebooted, upon next detection, the device is getting a different ID. This means that I have to manually
remove old devices from the devices list, then manually clean data from Developer tools->statistics, then manually add the same devices with new ID to new/existing dashboards. Then the cycle continues.
An example - I have Thermopro TX2 sensor. It was registered as Thermopro-TX2-9-1-102. From this name, Thermopro-TX2-9 does not change. -1- is one of the three frequencies one can select by moving the switch, and 102 is the device ID assigned (my assumption) - by RTL_433.
Everything worked fine, until I replaced the batteries on the sensor. This time the device came back as Thermopro-TX2-9-1-30. So I had to go and update everything.
The above becomes clear if I run MQTT Explorer. You can see below that while I have just three Thermopro devices, there are more than one instance of each device if the device was powered on/off.
The same can be seen with other devices as well - you can see a number of entries under TPMS-Schradar.
So the question is - is all this situation unavoidable?
I think that number is something your devices is adding to make it possible to use more devices on the same channel.
Could you please clarify what you mean?
In terms of Thermopro devices there are only three channels marked as 1/2/3, nothing else.
For other devices there no other devices on the same frequency with the same ID.
If you have some noise on one or two channels that makes those channels unusable to thermopro devices or if you have more than 3 thermopro devices, then they can still be used, because they can all run on the same channel.
If a thermopro device happens to use the same channel and get the same ID (those 1-3 last digits) then the user will discover it and just take out the batteries and reinsert them for another ID to be assigned.
The manufacturer did not make a way to identify a specific device, because it was probably not important.
