I use packages to simplify my ESPHome code, but I was wondering if I could call a block of code instead of repeating it in every yaml file?
I don’t think a script would work. I want to externalize three components and as I understand it script can only execute one component. I am looking for something like a simple #include which would at compile time import the contents of the included file.
This is what I would like to reduce to a single line:
# Status light
# lit, with quick off’s: No connection
# steady flashing: WiFi connection
# short ‘on’ pulses: connected to HA API
interval:
- interval: 2s
then:
if:
condition:
wifi.connected:
then:
- if:
condition:
api.connected:
then:
- light.turn_on:
flash_length: 1950ms
else:
- light.turn_on:
flash_length: 1000ms
else:
- light.turn_on:
flash_length: 50ms
light:
- platform: binary
internal: true
output: status_led_out
output:
- id: status_led_out
platform: gpio
pin: ${led_pin}
As I type this I realize that an #include like this would preclude the use of the output: or light: components in my yaml file.
Never mind. I was just looking for a way to reduce the number of lines in my device yaml file. Just using two packages has reduced my yaml file that I can print most of them on one page:
packages:
wifi: !include common/wifi.yaml
device_base: !include common/esp8266.yaml
