Can you help me with that question? Is there any free service to expose Hassio to the web (that works with google assistant integration)?
I am behind a CGNAT so DuckDNS won’t work.
NabuCasa is very good but it is a paid service about $5/month
I can use Ngrok for free but then each 2 or 3 days it will change the tunnel address and I have to configure everything all over again which is kinda annoying. The paid version would solve the problem but then I would have to pay $5/month.
The thing is… $5 seem like a good price but considering the COVID situation and the huuuuge variation in the currency exchange, it became a little bit expensive for me.
So… I am searching for a free alternative. Does anyone knows any other method?
Does your ISP support IPv6? If so, connecting remotely using IPv6 would be a solution. To avoid setting home assistant to only listen to requests from IPv6 addresses, I run an NGINX reverse proxy which I can connect to with IPv6 and then it just forwards requests to my server’s IPv4 address.
I am using NGROK and not sure what you mean that you have to configure everything when NGROK tunnel number changes.
The regular set up (following instructions). When ever the ngrok changes its URL I get a text message via telegram with the new link. When at home I just use the desktop shortcut on my phone to access the HA control panel. When away from home I just open the telegram and look for the last link I got. That gives me access to my home assistant control panel.
Just the other day I was playing with my router. I changed the configuration, and next thing I know my router has been assigned an IPv6 IP from the ISP modem/router.
I don’t expect you to give me steps by steps instructions on how I can now use this IPv6 address to get access my system from the outside, but can you suggest some key words I can use, or a good link?
How you set it up is going to vary a bit depending on what router you have. You won’t use your router’s IPv6 address though. Any device that supports IPv6 will have its own global (public) IPv6 address, so you’ll want to set up a firewall/port opening rule using whatever your home assistant host’s global IPv6 address is. I have an edgerouter x, so I have WAN IN firewall rules set up for these things.
Feel free to DM me here or on Discord if you want–always happy to bring someone to the light that is IPv6
