As you know, I have copied your Stomverbrauch / Wärmemenge / Verhältnis for my dashboard. However, as the new year started, I’d like to have “this year”-values.
To create this, I need entities that reset the values of produced_heating_total and consumed_heating_total on every January 1st. Do you have any idea how I can do that? Of course I could do it manually (create an entity that subtracts the value from January 1st 2024 of the total value from today’s total value) - but then I’d have to adjust it every year manually. Do you know a way so this gets done automatically?
After installing everything necessary for cooling and enabling it, I noticed that anything cooling related (except for the “iscooling” entity) is not functional.
I can neither set the cooling temperature nor can I change the mode or anything.
Hello Ingo, first of all thank you for the Stiebel Eltron integration via HACS. I don’t understand why I need the modbus.yaml file. The integration already delivers all elements automatically.
Yes, over here it’s exactly the same. All the entities for cooling are disabled. I don’t care, because I can’t use my heatpump for cooling (because I use radiators) and we have AC’s installed in our house.
Hi. I am very impressed with the amount of work that has gone into mastering STIEBEL ELTRON heat pumps.
I have a question, has anyone tried to control an additional PV-E-E heater via modbus?
