OverZealous
(Phil DeJarnett)
January 26, 2025, 9:32pm
1
I have a custom voice automation, which a trigger that includes in [the|our|my] {area}
. I’m using this to filter entities by area, using area_entities
In general it works, but it only works for the original name. It never works for an alias name. I’ve tried all the visible area_*
filters, but none of them seem to recognize aliases.
Are aliases not available to templates? I’ve searched on the forums, but can’t seem to find an answer.
It’s not a huge deal, but it would make it much nicer to expand on the core functions if we could do that.
mchk
January 27, 2025, 12:00am
2
This is a known problem, but it has not yet been solved
home-assistant:dev
← home-assistant:synesthesiam-20240606-get-by-name-aliases
opened 03:42PM - 06 Jun 24 UTC
## Proposed change
Describe the big picture of your changes here to com… municate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
The `async_get_area_by_name` and `async_get_floor_by_name` functions on their respective registries do not currently check for aliases. Because of this, working with area/floor aliases in templates is not possible (the `area_id` and `floor_id` template functions use `get_*_by_name`).
This PR extends the two `get_*_by_name` functions to also check aliases. The `normalize_name` function from `normalized_name_base_registry` is reused.
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [ ] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [x] New feature (which adds functionality to an existing integration)
- [ ] Deprecation (breaking change to happen in the future)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: fixes #
- This PR is related to issue: https://github.com/home-assistant/intents/issues/2212
- Link to documentation pull request:
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [ ] The code change is tested and works locally.
- [ ] Local tests pass. **Your PR cannot be merged unless tests pass**
- [ ] There is no commented out code in this PR.
- [ ] I have followed the [development checklist][dev-checklist]
- [ ] I have followed the [perfect PR recommendations][perfect-pr]
- [ ] The code has been formatted using Ruff (`ruff format homeassistant tests`)
- [ ] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
- [ ] Untested files have been added to `.coveragerc`.
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone+-status%3Afailure
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/development_checklist/
[manifest-docs]: https://developers.home-assistant.io/docs/creating_integration_manifest/
[quality-scale]: https://developers.home-assistant.io/docs/integration_quality_scale_index/
[docs-repository]: https://github.com/home-assistant/home-assistant.io
[perfect-pr]: https://developers.home-assistant.io/docs/review-process/#creating-the-perfect-pr
OverZealous
(Phil DeJarnett)
January 27, 2025, 12:32am
3
Thanks! It wasn’t showing up for me in my searches.
Honestly, I’d love to see some sort of generic get_entities_by_name(name)
, which figures out if it’s explicitly named entity, a device, an area, floor, or labels, and can return the most relevant match, maybe with a get_all_entities_by_name(name)
which returns any match across any type of name.
