Hi all,
I installed the Tuya Local integration in Home Assistant and want to add a motion sensor (PIR) manually.
Here is what I did:
- Created a YAML device file with the sensor’s configuration (no syntax errors, placed correctly under
/config/custom_components/tuya_local/devices/). - In Home Assistant, I went to Add Integration > Tuya Local > Add Manually.
- Entered the device’s ID, Local Key, and local IP address. The device is detected, but the device type options shown don’t match my motion sensor at all (e.g., hornbill_y4_smart_lock, s11_rfir_remote, arlec_rf_transmitter, etc.).
I tried with a YAML file that includes the device ID and without it, but the result is the same.
I would appreciate any help or guidance on how to properly define the YAML so that the integration recognizes my device and allows me to use the motion sensor.
The sensor model is P01
My YMAL:
name: PIR Motion Sensor
products:
- id: *****(HIDDEN)
model: PIR-Custom
entities:
- entity: binary_sensor
class: motion
dps:
- id: 101
type: string
mapping:
- dps_val: pir
value: true
- dps_val: none
value: false
- entity: sensor
class: battery
category: diagnostic
dps:
- id: 102
type: string
mapping:
- dps_val: high
value: 100
- dps_val: medium
value: 60
- dps_val: low
value: 20
Thanks a lot!
