Issue creating automation using Aqara H2 light switch over Matter
Like many I’ve seen in the forum, I’m new to Home Assistant. The automations I’ve done so far have been using Apple’s Home app. But now, in our new house, there are devices that are not compatible with HomeKit, so I’ve decided to give a go to Home Assistant.
I’ve several Aqara H2 light switches, and they work well. The relay button works, even when the switch is not adopted by anything, which was my goal. I’ve added the switches to HomeKit via Thread, and there I can setup the WiFi buttons, but I’m limited to whatever devices HomeKit supports.
In Home Assistant, I’ve added all devices, including the light switches and other devices. I’ve tried to add an automation that, when the WiFi button is pressed, it should turn ON the electric tower radiator. After several attempts, I’ve accomplished nothing. I’ve looked in the Developer Tools to see which event type was triggered, and it was the following:
event_type: state_changed
  entity_id: event.aqara_smart_wall_switch_button_5_4
  old_state:
    state: "2025-11-24T10:49:39.931+00:00"
    attributes:
      event_types:
        - initial_press
      event_type: initial_press
      newPosition: 1
      device_class: button
      friendly_name: Bathroom light switch Button (5)
    last_changed: "2025-11-24T10:49:39.931471+00:00"
    last_reported: "2025-11-24T10:49:39.931471+00:00"
    last_updated: "2025-11-24T10:49:39.931471+00:00"
    context:
      parent_id: null
      user_id: null
  new_state:
    state: "2025-11-24T10:49:50.587+00:00"
    attributes:
      event_types:
        - initial_press
      newPosition: 1
    last_changed: "2025-11-24T10:49:50.588060+00:00"
    last_reported: "2025-11-24T10:49:50.588060+00:00"
    last_updated: "2025-11-24T10:49:50.588060+00:00"
    context:
      parent_id: null
      user_id: null
origin: LOCAL
time_fired: "2025-11-24T10:49:50.588060+00:00"
context:
  parent_id: null
  user_id: null
I’ve tried several types of triggers, such as Entity, Device, Manual events, but no success.
I even connected the light switch to Home Assistant via Zigbee, but like this I couldn’t see the WiFi buttons. I read several older posts, saying it’s a limitation, or that it’s the trigger type, but nothing so far.
Has anyone been able to do something like this?
Thanks.
Hugo
I get your struggle, automating Matter buttons correctly is still cumbersome in HA.
This is the general tutorial to automate buttons, the main idea is automate on state change:
Luckily, the H2 only has initial press type so you don’t need the action conditions part where they check for the specific press type.
But you need the unavailable and unknown conditions, otherwise your automation will trigger for reasons that are not a button press.
The event automation is working really well and fast on the light switch H" (same by the way on the new shutter switch H2), but the events are still “fired” although there are “unavailable” and “unknown” condions in the automations are included. Anybody an idea what the problem could be? Actually, I´ve never seen the state “unknown” or “unavailable” in the state entity.
How could I check what state the event entity has when I e.g. kill the thread communication for a few seconds by unplugging the coordinator stick.
alias: Licht Ankleide an von Ankleide Taste 7 (rechts unten)
description: ""
triggers:
  - trigger: state
    entity_id:
      - event.ankleide_schlafzimmer_taste_7
conditions:
  - condition: not
    conditions:
      - condition: state
        entity_id: event.ankleide_schlafzimmer_taste_7
        state:
          - unavailable
      - condition: state
        state:
          - unknown
actions:
  - action: light.turn_on
    metadata: {}
      brightness_pct: 100
      color_temp_kelvin: 6500
      entity_id: light.ankleide_schlafzimmer_leuchte_1
mode: single
I have created a blueprint automation that does all the logic and conditions. Based on device type (if it also supports double/long press) it will automatically select between initial_press or multi_press_1.
You only need to select the entity, any additional conditions (optional) and actions for each type of press. You only need to fill the conditions and actions of the press types you want to configure.
You can find my blueprint here:
I also had the issues with random event firing after some home assistand or matter restarts.
I changed now the automation to the one below that should have fixed it.
See the not_from for the unkonwn and unavialable states (need to be added via yaml as UI does not support them)
alias: Schlafzimmer Kastenbeleuchtung
description: ""
triggers:
  - trigger: state
    entity_id: event.aqara_smart_wall_switch_button_7
    not_from:
      - unknown
      - unavailable
conditions:
  - condition: state
    attribute: event_type
    state: initial_press
actions:
  - type: toggle
    device_id: ebb32145f0b91de4af7e0988b9a7314f
    entity_id: 643fd6fb7cd9eb8e20d6b7c9e615a767
    domain: switch
mode: single
