Issue - Front end: Input_Slider - Any values above 100 will show as 100 after restart
I found one minor issue with Input_slider for front end.
If you set any values above 100, after restart front end, front end will show 100… (The set value is still at set value. No change)
Anything below 100 will show correctly after restart
Can this be fixed?
Set value at 300:
After restart frontend:
I still experience this issue, as described by @Supakdee_Sodsriwiboo.
When I restart Home Assistant from the front end and leave the browser open at the page where the sliders are, it loads the values of the input sliders correctly. But when I press F5 (refresh the front end), all the sliders above 100 will immediately jump back to the value 100.
Does anyone have a solution for this?
Thanks in advance,
I can confirm this issue. No restart needed. After some time the sliders show 100.
Value in the database is already the higher value, only the frontend shows it wrong.
Is this already a formal issue that you know about? Or can we report it somewhere?
I filed an issue on this.
Thank you very much for your effort @VDRainer!
