Issue login into ha using a private (Pangolin) tunnel with TOTP 2fa
It is not possible to login through a private tunnel using TOTP 2fa (in my case with Pangolin). After leaving the app to copy the TOTP I have to start over with the username/password entry - is there a chance to keep this information when changing the app, or is this an iOS security feature.
In addition I would appreciate a significantly higher timeout until the disconnect message appears - it is not even possible to enter the username when it is an email address - took some time to figure out that I can use X on the top right to continue.
