I have hass and nod-rede containers on ubuntu (ip1). Worked fine locally.
I’m trying to setup nginx+letsencrypt on other ubuntu server(ip2) and trying to setup proxy for hass and node-red. The SSL setup is for all sub-subdomain of duckdns.org.
Below is the config for hass:
server {
listen 443 ssl;
listen [::]:443 ssl;
server_name myha.xxxxxxxxxx.duckdns.org;
include /config/nginx/ssl.conf;
client_max_body_size 0;
location / {
include /config/nginx/proxy.conf;
resolver 127.0.0.11 valid=30s;
set $upstream_homeassistant ip1;
proxy_pass http://$upstream_homeassistant:8123;
location /api/websocket {
proxy_set_header Host $host;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
for node-red:
server {
listen 443 ssl;
server_name nr.xxxxxxxxxx.duckdns.org;
location / {
proxy_pass http://ip1:1880/;
location /ui {
proxy_pass http://ip1:1880/ui;
also in configuration.yaml file:
http:
base_url: myha.xxxxxxxxxx.duckdns.org
Now hass seems to work fine using https://myha.xxxxxxxxxx.duckdns.org
But when loading https://nr.xxxxxxxxxx.duckdns.org, first it loads ok and showing my flow, but immediately it showing “lost connection to the server, reconnecting…”
What configuration do I missed? Thanks!
