Issue pairing IKEA Tradfri 806lumen e26 with ZHA
I have 2 types of bulbs
TRÅDFRI LED bulb E26 806 lumen, wireless dimmable white spectrum/globe clear - IKEA
and the one provided in this kit
TRÅDFRI Remote control kit, color and white spectrum - IKEA
I have no issue to link the one provided in the kit but I have no luck with the first one.
I’m using homeassistant latest version and my zigbee coordinator is a conbee2
On the database I only found the bulb e27
[IKEA Tradfri LED bulb E27 806 lumen, dimmable, white spectrum, clear (LED1736G9) Zigbee compatibility (blakadder . com)]
But one thing that is bugging me, in the the database for the e27, the zigby id is: Zigbee ID: “TRADFRI bulb E26 WS clear 806lm”
When I put them in pairing mode, I don’t see anythings in the logs
Any idea?
Few more info:
On the bulb, it’s clearly stated the product number: LED1736G9 E26. the same that is used in the database
IKEA Tradfri LED bulb E27 806 lumen, dimmable, white spectrum, clear (LED1736G9) Zigbee compatibility (blakadder.com)
But not the same product code: that I bought: 704.084.73
I’m so dumb…
Sorry - The “reset” to factory should be done from the “on” position. So I never got into pairing mode.
It work now with this:
How to reset a TRÅDFRI light bulb - YouTube
For the video averse:
turn off and on 6 times in a row, then it will pair.
Hi Mathieu
were you please able to change the brightness or only turn on and off the LED1736G9 through ZHA? When checking the entity I can change the brightness but on the dashboard I can only turn on / off, also in node red only on / off
