Hi all –
Had an RPi w/ Hassio installed, recently upgraded to a NUC and installed Hassio via Docker using this guide [https://www.smarthomebeginner.com/docker-home-media-server-2018-basic/]. I am managing the Docker containers w/ the Portainer add-on.
Everything seems to be working well, ZHA/Zwave, Thermostat, various add-ons (including Nginx manager and Pi-hole).
The problem is the Discovery component doesn’t seem to be working as it was with my prior, non-Docker installation. Most of the various items on the network are found as they had been before [AppleTV, Logitech Harmony, etc].
Additionally, when I install the HA Beta iPhone app, I am able to connect, but, nothing is ever added to my iOS integration. I have removed the app, reset it, logged in again, waited, rebooted to no avail.
Annoyingly, two Homekit assets are found (my Ecobee thermostat, which I’ve already added through ecobee: component and Wemo’s, which, don’t actually show or add properly) and I am unable to permanently dismiss or ignore them.
When searching around I saw you must use ‘host’ flag when setting up the container, I don’t recall doing that specifically, but I see that in Portainer my home assistant docker is using ‘host’ as the network.
Everything else seems to be working properly – sorry for the long message but wanted to make sure it was detailed enough. I attached the discovered Homekit integrations I would like to ignore or fix through a working discovery component. Any help much appreciated!
