Issue wich hangs frontend for several min
hi i have an issue with HA which is ginving me the following error:
Logger: frontend.js.latest.202009180
Source: components/system_log/init.py:193
First occurred: 18:34:06 (1 occurrences)
Last logged: 18:34:06
https://unpkg.com/[email protected]/min/moment.min.js:1:144 Uncaught TypeError: Cannot set property ‘moment’ of undefined
Not sure where to look, i saw that the clockcard uses this js, so rmoeved that one, but it still occurs. Any pointers?
Thanks in advance.
Bart
In JavaScript almost everything is an object, null and undefined are exception. if a variable has been declared, but has not been assigned a value, is automatically assigned the value undefined . Therefore, if you try to access the value of such variable, it will throw Uncaught TypeError cannot set property ‘0’ of undefined/null .
JavaScript null and undefined is one of the main reasons to produce a runtime errors . This happens because you don’t check the value of unknown return variables before using it. If you are not sure a variable that will always have some value, the best practice is to check the value of variables for null or undefined before using them. The standard way to catch null and undefined simultaneously is this:
if (variable == null) {
// your code here.
Because null == undefined is true, the above code will catch both null and undefined.
Also you can write equivalent to more explicit but less concise:
if (variable === undefined variable === null) {
// your code here.
This should work for any variable that is either undeclared or declared and explicitly set to null or undefined.
