I have a goodnight routine that I use to do many things, one of which is turn off a light group I created called light.all_lights. Since upgrading to 2023.7.x I have gotten an error when getting to that step of my automation. The automation stops and I get the following errors in my logs.
Logger: homeassistant.components.automation.good_night
Source: components/zha/light.py:471
Integration: Automation (documentation, issues)
First occurred: July 13, 2023 at 9:45:03 PM (22 occurrences)
Last logged: July 17, 2023 at 9:40:59 PM
🏠House Mode: Night: Parallel action at step 1: parallel 2: Error executing script. Unexpected error for call_service at pos 1:
🏠House Mode: Night: Error executing script. Unexpected error for parallel at pos 1:
While executing automation automation.good_night
🏠House Mode: Night: Error executing script. Unexpected error for call_service at pos 4:
🏠House Mode: Night: Error executing script. Unexpected error for call_service at pos 13:
File "/usr/local/lib/python3.11/site-packages/zigpy/device.py", line 310, in request
return await req.result
asyncio.exceptions.CancelledError
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 468, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 703, in _async_call_service_step
response_data = await self._async_run_long_action(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 665, in _async_run_long_action
return long_task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1965, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2005, in _execute_service
return await cast(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 235, in handle_service
return await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 848, in entity_service_call
response_data = task.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1192, in async_request_call
return await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 892, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 593, in async_handle_light_off_service
await light.async_turn_off(**filter_turn_off_params(light, params))
File "/usr/src/homeassistant/homeassistant/components/group/light.py", line 194, in async_turn_off
await self.hass.services.async_call(
return await cast(
return await coro
result = await task
return await cast(
return await coro
result = await task
File "/usr/src/homeassistant/homeassistant/components/zha/light.py", line 471, in async_turn_off
result = await self._on_off_cluster_handler.off()
File "/usr/local/lib/python3.11/site-packages/zigpy/util.py", line 132, in retry
return await func()
File "/usr/local/lib/python3.11/site-packages/zigpy/zcl/__init__.py", line 375, in request
return await self._endpoint.request(
File "/usr/local/lib/python3.11/site-packages/zigpy/endpoint.py", line 253, in request
return await self.device.request(
File "/usr/local/lib/python3.11/site-packages/zigpy/device.py", line 309, in request
async with asyncio_timeout(timeout):
File "/usr/local/lib/python3.11/asyncio/timeouts.py", line 111, in __aexit__
raise TimeoutError from exc_val
TimeoutError
and
First occurred: July 13, 2023 at 10:07:09 PM (11 occurrences)
Last logged: July 17, 2023 at 9:47:04 PM
Error doing job: Task exception was never retrieved
return await coro
result = await task
return await cast(
return await coro
result = await task
return await func()
TimeoutError
automation trace and config below
alias: "🏠House Mode: Night"
- entity_id:
- input_select.house_mode
platform: state
to: Night
condition:
- condition: template
value_template: "{{ trigger.from_state.state != 'unavailable' }}"
- condition: time
after: "20:00:00"
before: "02:00:00"
- condition: or
conditions:
- condition: state
entity_id: input_select.house_mode
state: Evening
- condition: state
state: Night
- data: {}
service: switch.turn_on
entity_id:
- switch.lockup_home
- group.alexa_do_not_disturb_switch
- service: script.music_sound_machine
volume: 0.3
device: media_player.master_bedroom_echo_show
enabled: true
- service: fan.set_percentage
percentage: 50
entity_id: fan.master_bedroom_fan
enabled: true
- service: fan.turn_off
data: {}
entity_id: fan.downstairs_fans
- service: script.living_room_fan_turn_off
data: {}
- data: {}
entity_id: group.tvs
service: homeassistant.turn_off
- service: number.set_value
entity_id:
- number.milford_base_station_volume
- number.entryway_keypad_volume
- number.basement_keypad_volume
value: "10"
- service: switch.turn_off
entity_id: switch.master_bedroom_laptop_charger
data: {}
- data: {}
entity_id: group.adaptive_lights_sleep_mode
- delay:
hours: 0
minutes: 0
seconds: 30
milliseconds: 0
- data: {}
service: script.house_secure_notification
- service: light.turn_off
data: {}
entity_id: light.outside_lights
data: {}
enabled: true
entity_id: light.all_lights
mode: single
