Issue with automation with numeric state
Trying to get home assistant to switch on lights when it’s cloudy (> 60%). This is my code . Any suggestions?
- alias: "Turn on cloudiness scen when >60 % and someone home"
      platform: numeric_state
      entity_id: sensor.yr_cloudiness
      value_template: '{{ state.attributes.battery }}'
      above: 60
    condition:
      condition: state
      entity_id: device_tracker.androidce4eef065a60770clan
      state: home
      service: scene.turn_on
      entity_id: scene.slck_alla_lampor
Why are you using the value_template? Try removing that line and test if that triggers the automation.
Solved unfortunately not the problem. Wrote code like this
-alias: "Turn on cloudiness scen when >60 % and someone home"
          above: 60
        condition:
          condition: state
          state: home
Yeah, you could have used the above example if you called the right value in the template instead of state.attributes.battery though.
It would be nice to combine the yr_cloudiness and the sun elevation to turn on lights when it is getting dark. Any ideas of a smart way of doing so?
What shall i wirite insted off state.attributes.battery on the Line templates. Can’t get it work? I will use sensor.yr_cloudiness
That should be correct.
For some reason the following automation does never trigger (the sensor updates correctly):
- alias: 'Phone battery low'
    entity_id: sensor.battery
    below: 25
  condition:
    condition: state
    entity_id: device_tracker.xxxxxx
    state: 'home'
    service: tts.google_say
    entity_id: media_player.home_group
    data_template:
      message: 'Your smartphone battery is at {{  states.sensor.battery.state }} percent. Dont forget to charge your phone.'
Any idea what’s wrong?
    below: '25'
    value_template: '{{  states.sensor.battery.state  }}'
Also doesn’t work.
Also tried this:
    below: 25
Same issue here with temperature values like 50.5
  entity_id: sensor.temperature
  #value_template: '{{ state.sensor.temperature }}'
  above: 40
I’ve tried with and without the value_template, above as “40” and “40.0”, nothing works.
Any hints?
has anyone gotten this to work? I also wanted to try an automation using numeric_state, but it’s not triggering.
I want to turn on some lights when it’s getting dark. Instead of using a sunset trigger with an offset, I decided to use a luminance sensor:
alias: 'Turn On Movie Lights After Sunset'
  - platform: numeric_state
    entity_id: sensor.fibaro_system_fgms001_motion_sensor_luminance_17_3
    below: 3.0
    value_template: '{{ state.state }}'
condition:
  - condition: and
    conditions:
      - condition: numeric_state
        below: 3.0
      - condition: or
        conditions:
There’s another trigger and some more conditions in the or-Part, but those worked reliably so far when I used a sunset trigger/condition.
I just replaced the latter with the numeric_state trigger/condition and it hasn’t worked since.
I’m not even sure if I’d need the value_template since the value I want to trigger on is the sensor’s state and not one of the attributes.
Unfortunately the documentation does not state if this is optional or not.
The numeric_state condition example in the docs uses states.state and I’m guessing that this is expanded to states.<entity_id>.state - however, my lights stay dark.
I also already tried without the value_template line, but with the same result.
Can anyone enlighten me how to use this correctly?
Sebastian
Upgraded to 0.41 today and now my automation worked! :slight_smile:
Sebastian
