Issue with CC1101 RF TX - cannot get clean signal
CC1101 + ESP32 TX corrupted pulses — transmit_raw glitching mid-signal
Hardware: Freenove ESP32-D0WD-V3 + blue CC1101 433M V2.0 module
ESPHome: 2026.5.1 (tried both arduino and esp-idf frameworks)
Wiring:
  • GDO0 (pin 3) → GPIO4 (TX)
  • GDO2 (pin 8) → GPIO2 (RX)
  • CSN → GPIO5, SCK → GPIO18, MOSI → GPIO23, MISO → GPIO19
Problem: RX works perfectly. TX emits RF (confirmed via second CC1101 slave receiver) but the transmitted signal is consistently corrupted — wrong pulse count (382-384 instead of 385) and glitched values like 1017, 1284, 1289 appearing mid-signal in frame 2 or 3.
What I've tried:
  • gdo0_pin removed from cc1101 block (fixed the no-RF issue from #16876)
  • rmt_symbols: 256 and rmt_symbols: 512
  • Both arduino and esp-idf frameworks
  • Single frame with repeat: times: 5, wait_time: 0s
  • Full 3-frame array as single transmit call
  • idle: 30ms on receiver to get clean captures
Clean capture from slave (physical remote, 385 pulses, consistent across multiple presses — fixed code confirmed):
[271, -499, 267, -499, 264, -516, 275, -507, 263, -509, 239, -533, 239, -533, 239, -510, 4384, -521, 514, -240, 256, -530, 509, -264, 269, -497, 264, -499, 267, -512, 515, -268, 500, -247, 266, -523, 245, -516, 245, -517, 265, -513, 510, -265, 525, -244, 514, -246, 267, -523, 515, -240, 256, -534, 499, -259, 267, -507, 515, -246, 517, -251, 535, -263, 496, -268, 266, -496, 270, -501, 257, -516, 515, -260, 260, -497, 274, -511, 263, -497, 269, -500, 538, -224, 534, -262, 497, -267, 527, -251, 497, -245, 548, -224, 536, -253, 506, -258, 529, -238, 530, -265, 506, -264, 499, -244, 535, -247, 516, -261, 524, -242, 528, -253, 270, -498, 522, -236, 523, -265, 507, -265, 507, -256, 524, -243, 529, -247, 262, -495, 267, -528, 516, -241, 267, -498, 267, -499, 543, -237, 252, -515, 264, -516, 521, -262, 499, -4368]
One frame ending at inter-frame gap -4368. Full signal has 3 frames.
What slave receives when master transmits (corrupted):
[275, -493, 293, -477, 269, -505, 274, -515 ... 1017, -540, 519 ...]
Corruption position is consistent across all attempts. Target device (433.92MHz pergola remote, fixed code) does not respond.
Current master config (TX only):
cc1101:
  cs_pin: GPIO5
  frequency: 433.92MHz
  output_power: 10
  modulation_type: ASK/OOK
  filter_bandwidth: 200kHz
remote_transmitter:
  pin: GPIO4
  carrier_duty_percent: 100%
  rmt_symbols: 256
  on_transmit:
    then:
      - cc1101.begin_tx: cc1101_module
  on_complete:
    then:
      - cc1101.begin_rx: cc1101_module
Does anyone have any ideas on where to go from here? I've seemingly tried hundreds of combinations without success (although at least now I have a device confirmed transmitting as there seems an issue with RX and TX on the same setup).
Always same exact pulse?
Did you try swapping tx and rx hardware?
The corruption position is consistent (always late in frame 2 or early frame 3) but the exact glitch value varies between transmissions — values like 1017, 1284, 1289 have all appeared at different times.
I've tried switching the GDO0/GDO2 pin assignment pin assignments and using two different CC1101 module/esp32 boards pair (i.e. one for RX and one for TX and then swapped) but they are the same hardware units as it seems the CC1101 is pretty much the only module I can find in Australia.
But your capture is only 148 pulses, not 385.
That's expected if one edge is missing. So for example...543, -237, 252, -515, ... becomes merged as 1032, -515 .
Is it always high pulse (positive)?
Is your Esp busy doing other things? Try with bare minimum configuration, just essential components and CC1101 + remote transmitter (no receiver config for TX). And set RMT symbols to 512.
Sorry let me go back to basics as I've looked at this so long I'm likely confusing concepts:
Receiver config:
esphome:
  friendly_name: CC1101 RF Receiver Slave
esp32:
  board:
spi:
  clk_pin: GPIO18
  mosi_pin: GPIO23
  miso_pin: GPIO19
cc1101:
  cs_pin: GPIO5
remote_receiver:
  pin: GPIO2
  dump: raw
  filter: 150us
  idle: 20ms
  buffer_size: 2kb
Receiver from the real remote. 3 presses of the same button to record a few tries:
Try 1
[22:00:37.152][I][remote.raw:026]: Received Raw: 283, -485, 264, -511, 264, -514, 263, -499, 269, -500, 259, -523, 243, -531, 262, -504, 4356, -510, 521, -257, 270, -501, 508, -251, 261, -513, 268, -499, 288, -502, 497, -269, 512, -246, 266, -520, 243, -529, 248, -512, 263, -512, 510,
[22:00:37.152][I][remote.raw:026]:   -264, 497, -269, 512, -246, 267, -520, 514, -240, 267, -501, 524, -245, 280, -496, 515, -264, 520, -241, 525, -247, 515, -246, 268, -520, 243, -531, 262, -504, 496, -270, 262, -497, 268, -513, 246, -517, 265, -513, 509, -265, 523, -245, 515, -246,
[22:00:37.160][I][remote.raw:026]:   519, -260, 524, -240, 526, -254, 521, -244, 527, -248, 513, -252, 507, -258, 531, -238, 530, -241, 525, -247, 517, -245, 519, -250, 534, -262, 250, -499, 522, -256, 523, -244, 529, -247, 514, -261, 498, -266, 525, -252, 269, -497, 246, -517, 513,
[22:00:37.175][I][remote.raw:026]:   -267, 266, -498, 269, -501, 509, -251, 260, -512, 266, -523, 511, -264, 508, -4341, 4376, -515, 522, -244, 276, -496, 515, -264, 252, -514, 263, -499, 269, -500, 510, -250, 535, -262, 250, -500, 289, -500, 242, -522, 264, -509, 519, -236, 521, -267,
[22:00:37.181][I][remote.raw:026]:   499, -249, 266, -522, 520, -236, 252, -519, 523, -255, 270, -501, 506, -261, 524, -238, 531, -267, 497, -247, 264, -521, 245, -514, 246, -519, 522, -255, 269, -501, 256, -522, 243, -528, 247, -513, 509, -266, 523, -245, 514, -246, 518, -260, 498,
[22:00:37.217][I][remote.raw:026]:   -262, 533, -266, 496, -264, 498, -269, 512, -247, 517, -260, 524, -240, 523, -263, 498, -268, 511, -246, 516, -260, 524, -240, 265, -501, 522, -268, 510, -247, 516, -261, 523, -240, 526, -255, 521, -244, 249, -512, 268, -509, 511, -264, 262, -513,
[22:00:37.235][I][remote.raw:026]:   264, -497, 523, -244, 277, -486, 267, -512, 511, -264, 506, -4369, 4353, -537, 508, -254, 269, -502, 507, -251, 260, -510, 266, -522, 241, -517, 521, -254, 516, -244, 279, -510, 243, -512, 265, -497, 265, -516, 520, -262, 508, -255, 515, -244, 280,
[22:00:37.256][I][remote.raw:026]:   -496, 516, -265, 252, -514, 521, -253, 270, -502, 503, -261, 524, -240, 527, -252, 522, -243, 250, -511, 268, -509, 265, -496, 534, -265, 237, -509, 265, -522, 268, -496, 247, -515, 514, -267, 499, -276, 516, -244, 527, -247, 514, -261, 498, -266,
[22:00:37.273][I][remote.raw:035]:   501, -277, 495, -269, 500, -273, 513, -253, 507, -258, 530, -238, 531, -241, 507, -259, 535, -252, 521, -243, 248, -523, 514, -265, 500, -257
Try 2
[22:01:52.830][I][remote.raw:026]: Received Raw: -4204, 296, -472, 296, -500, 244, -516, 268, -494, 264, -512, 265, -511, 240, -533, 239, -536, 4352, -515, 515, -268, 239, -523, 494, -269, 249, -521, 244, -532, 262, -504, 523, -244, 513, -247, 265, -521, 243, -529, 247, -513, 264, -511,
[22:01:52.858][I][remote.raw:026]:   510, -264, 499, -268, 512, -247, 265, -520, 513, -241, 266, -501, 524, -245, 280, -509, 518, -236, 520, -268, 499, -249, 520, -269, 246, -520, 245, -530, 247, -514, 509, -265, 267, -498, 265, -506, 272, -493, 268, -499, 522, -257, 523, -243, 530,
[22:01:52.858][I][remote.raw:026]:   -247, 515, -252, 507, -258, 529, -238, 530, -267, 498, -248, 518, -245, 519, -249, 536, -261, 495, -267, 501, -275, 495, -269, 498, -273, 512, -262, 250, -499, 523, -257, 522, -245, 527, -247, 514, -261, 497, -266, 500, -277, 268, -497, 245, -517,
[22:01:52.858][I][remote.raw:026]:   514, -266, 266, -497, 269, -500, 509, -249, 261, -516, 267, -500, 516, -266, 524, -4349, 4370, -519, 502, -261, 252, -527, 496, -258, 269, -501, 256, -513, 267, -508, 511, -264, 507, -264, 237, -532, 260, -508, 268, -496, 264, -497, 517, -263, 520,
[22:01:52.858][I][remote.raw:026]:   -268, 497, -248, 264, -522, 492, -263, 253, -515, 510, -266, 267, -498, 519, -247, 516, -260, 524, -266, 500, -254, 269, -502, 254, -521, 243, -528, 491, -265, 267, -498, 266, -522, 244, -514, 246, -518, 534, -241, 524, -246, 515, -246, 519, -250,
[22:01:52.871][I][remote.raw:026]:   535, -262, 496, -266, 499, -275, 495, -245, 522, -250, 535, -262, 496, -267, 500, -275, 517, -243, 526, -248, 511, -262, 498, -264, 262, -514, 496, -278, 515, -244, 527, -247, 514, -261, 497, -266, 526, -252, 266, -483, 286, -486, 516, -258, 259,
[22:01:52.907][I][remote.raw:026]:   -529, 262, -503, 496, -270, 260, -507, 248, -517, 514, -267, 499, -4360, 4391, -492, 519, -246, 269, -520, 514, -266, 239, -526, 268, -497, 264, -497, 516, -264, 521, -240, 266, -497, 268, -523, 245, -514, 246, -518, 510, -265, 523, -246, 516, -246,
[22:01:52.920][I][remote.raw:026]:   268, -521, 514, -265, 229, -535, 497, -276, 243, -522, 521, -237, 520, -267, 500, -249, 519, -269, 246, -519, 245, -530, 246, -517, 520, -254, 269, -502, 255, -515, 244, -530, 247, -515, 521, -254, 521, -244, 526, -248, 512, -251, 508, -258, 529,
[22:01:52.947][I][remote.raw:035]:   -262, 506, -267, 497, -249, 517, -246, 521, -249, 536, -262, 496, -264, 506, -266, 508, -258, 509, -251, 520, -246, 268, -521, 516, -265
Try 3
[22:02:30.717][I][remote.raw:026]: Received Raw: 275, -505, 244, -531, 262, -505, 261, -508, 261, -509, 262, -508, 267, -496, 266, -497, 4368, -511, 534, -252, 270, -502, 505, -261, 253, -503, 288, -501, 268, -497, 516, -246, 516, -261, 253, -503, 288, -504, 269, -497, 264, -498, 514,
[22:02:30.717][I][remote.raw:026]:   -265, 497, -266, 524, -245, 263, -496, 518, -264, 253, -514, 509, -267, 267, -496, 517, -245, 518, -250, 534, -262, 496, -267, 266, -499, 270, -501, 256, -521, 514, -240, 267, -501, 268, -499, 288, -486, 267, -510, 510, -265, 506, -265, 507, -257,
[22:02:30.717][I][remote.raw:026]:   517, -243, 531, -247, 514, -261, 523, -243, 523, -263, 512, -244, 512, -246, 517, -250, 533, -240, 534, -263, 495, -268, 501, -258, 516, -244, 281, -497, 516, -260, 505, -265, 505, -266, 507, -258, 510, -249, 518, -266, 247, -513, 268, -513, 513,
[22:02:30.717][I][remote.raw:026]:   -268, 266, -496, 270, -497, 522, -263, 250, -496, 264, -513, 508, -266, 524, -4346, 4366, -519, 519, -247, 263, -515, 513, -267, 240, -502, 260, -533, 236, -533, 507, -256, 523, -243, 276, -496, 243, -533, 262, -505, 268, -497, 518, -246, 516, -252,
[22:02:30.717][I][remote.raw:026]:   533, -263, 250, -497, 522, -255, 269, -501, 509, -251, 259, -516, 513, -268, 525, -251, 517, -244, 525, -247, 262, -514, 242, -526, 241, -518, 522, -256, 267, -507, 264, -509, 244, -512, 265, -498, 534, -265, 507, -263, 508, -254, 521, -244, 526,
[22:02:30.725][I][remote.raw:026]:   -248, 513, -262, 497, -268, 526, -251, 517, -243, 528, -247, 514, -262, 498, -268, 501, -259, 534, -226, 543, -243, 525, -248, 262, -516, 512, -240, 528, -254, 522, -244, 528, -247, 513, -262, 498, -265, 262, -514, 254, -507, 523, -247, 263, -522,
[22:02:30.751][I][remote.raw:026]:   243, -513, 515, -268, 266, -497, 269, -502, 507, -261, 524, -4356, 4364, -515, 525, -245, 260, -507, 521, -240, 261, -515, 268, -498, 289, -500, 498, -269, 511, -246, 265, -520, 243, -529, 262, -505, 268, -498, 516, -247, 515, -261, 525, -241, 266,
[22:02:30.774][I][remote.raw:026]:   -500, 514, -269, 260, -498, 515, -264, 253, -515, 509, -266, 523, -244, 513, -246, 518, -250, 260, -516, 268, -499, 289, -502, 507, -255, 271, -501, 256, -521, 243, -530, 262, -503, 523, -245, 512, -246, 517, -251, 534, -262, 496, -268, 501, -250,
[22:02:30.800][I][remote.raw:035]:   520, -245, 546, -247, 512, -261, 498, -267, 525, -236, 515, -270, 510, -246, 518, -261, 525, -242, 525, -263, 242, -525, 514, -248, 513, -262
The TX yaml:
esphome:
  friendly_name: CC1101 RF Transceiver
esp32:
  board: esp32dev
spi:
  clk_pin: GPIO18
  mosi_pin: GPIO23
  miso_pin: GPIO19
cc1101:
  cs_pin: GPIO5
remote_transmitter:
  pin: GPIO4
  rmt_symbols: 512
  on_transmit:
    then:
      - cc1101.begin_tx
  on_complete:
    then:
      - cc1101.begin_rx
button:
  - platform: restart
    icon: "mdi:remote"
    on_press:
      - remote_transmitter.transmit_raw:
          carrier_frequency: 0Hz
          code: [
            512, -246, 266, -520, 243, -529, 248, -512, 263, -512, 510, -264, 497, -269, 512, -246,
            265, -513, 509, -265, 523, -245, 515, -246, 519, -260, 524, -240, 526, -254, 521, -244,
            269, -497, 246, -517, 513, -267, 266, -498, 269, -501, 509, -251, 260, -512, 266, -523,
            521, -267, 499, -249, 266, -522, 520, -236, 252, -519, 523, -255, 270, -501, 506, -261,
            256, -522, 243, -528, 247, -513, 509, -266, 523, -245, 514, -246, 518, -260, 498, -262,
            526, -255, 521, -244, 249, -512, 268, -509, 511, -264, 262, -513, 264, -497, 523, -244,
            265, -516, 520, -262, 508, -255, 515, -244, 280, -496, 516, -265, 252, -514, 521, -253,
            527, -247, 514, -261, 498, -266, 501, -277, 495, -269, 500, -273, 513, -253, 507, -258,
Then an example of using the raw code sent from the TX as received by the receiver slave RX:
[23:01:36.915][I][remote.raw:026]: Received Raw: 300, -474, 281, -502, 265, -511, 266, -486, 286, -490, 262, -530, 240, -531, 263, -519, 4352, -492, 535, -244, 258, -508, 507, -271, 268, -477, 274, -513, 290, -520, 488, -268, 503, -257, 243, -524, 249, -542, 244, -499, 277, -489, 530,
[23:01:36.926][I][remote.raw:026]:   -257, 492, -269, 505, -261, 277, -511, 514, -243, 260, -481, 539, -246, 289, -474, 553, -224, 534, -262, 524, -242, 500, -257, 268, -507, 264, -514, 269, -496, 514, -269, 265, -472, 292, -498, 254, -520, 244, -528, 491, -291, 509, -239, 519, -244,
[23:01:36.926][I][remote.raw:026]:   532, -245, 543, -235, 523, -265, 499, -263, 514, -246, 537, -220, 519, -263, 549, -211, 530, -237, 541, -245, 514, -236, 525, -241, 548, -269, 265, -472, 541, -243, 523, -223, 555, -247, 513, -238, 497, -292, 524, -235, 296, -495, 234, -499, 539,
[23:01:36.926][I][remote.raw:026]:   -242, 280, -487, 288, -489, 509, -255, 242, -525, 273, -514, 514, -266, 523, -4324, 4366, -538, 512, -224, 285, -498, 541, -239, 254, -508, 265, -487, 287, -490, 534, -264, 512, -247, 263, -498, 290, -493, 245, -517, 265, -516, 509, -266, 499, -267,
[23:01:36.926][I][remote.raw:026]:   513, -224, 284, -494, 539, -241, 256, -505, 533, -263, 266, -472, 539, -246, 540, -208, 550, -266, 497, -238, 297, -494, 263, -499, 244, -508, 545, -243, 269, -494, 267, -523, 244, -513, 245, -518, 534, -242, 533, -252, 517, -244, 502, -276, 488,
[23:01:36.949][I][remote.raw:026]:   -263, 523, -294, 494, -235, 499, -270, 504, -261, 524, -237, 531, -266, 523, -243, 507, -269, 490, -245, 544, -246, 538, -224, 259, -516, 516, -269, 520, -234, 542, -219, 535, -245, 543, -247, 537, -236, 254, -499, 278, -487, 508, -282, 240, -525,
[23:01:36.982][I][remote.raw:026]:   291, -474, 518, -263, 251, -504, 261, -524, 484, -275, 513, -4368, 4364, -522, 517, -235, 278, -488, 542, -243, 269, -474, 285, -523, 223, -531, 516, -268, 526, -209, 320, -493, 236, -499, 268, -507, 262, -525, 534, -251, 492, -270, 500, -262, 252,
[23:01:36.997][I][remote.raw:026]:   -507, 522, -259, 270, -500, 525, -251, 282, -490, 514, -243, 530, -264, 507, -257, 517, -221, 268, -521, 243, -528, 246, -512, 558, -244, 241, -499, 291, -475, 301, -497, 243, -499, 523, -291, 477, -274, 514, -244, 526, -246, 540, -224, 508, -265,
[23:01:37.024][I][remote.raw:035]:   522, -267, 470, -276, 513, -266, 537, -243, 501, -262, 523, -243, 527, -255, 493, -247, 564, -243, 523, -223, 257, -511, 538, -241, 499
As an aside, thank you for looking into this I have seen your replies on other threads and it's super appreciated.
Comparing these two, nothing jumps on my eyes. Pulse count is same and there are no ~1000us "glitches".
Yes I suspect I got some config wrong upstream which I now fixed. The device still doesn't respond though even when it's 30cm away (much closer than the RX device itself which seems to register fine). Any ideas what might cause this?
30cm is too close. Few meters is good distance.
What do you get out with idle: 3ms on rx? It will cut the frames to separate captures, just to be sure it's not truncated .
Thanks to clarify I tested at multiple distances and still doesn't work. WIth config:
remote_receiver:
  pin: GPIO2
  dump: raw
  filter: 150us
  idle: 3ms
  buffer_size: 2kb
I get remote output of:
Try 1:
[17:55:43.750][I][remote.raw:035]: Received Raw: 326, -475, 253, -513, 244, -532, 261, -505, 265, -496, 266, -521, 244, -514, 246, -545
[17:55:43.818][I][remote.raw:026]: Received Raw: -495, 518, -263, 252, -517, 521, -255, 269, -500, 256, -513, 243, -530, 512, -266, 497, -276, 241, -509, 286, -483, 276, -495, 268, -527, 492, -266, 508, -258, 510, -275, 266, -509, 512, -247, 264, -514, 513, -261, 239, -517, 521, -255,
[17:55:43.824][I][remote.raw:026]:   515, -244, 533, -247, 515, -261, 252, -503, 288, -500, 237, -533, 508, -256, 268, -500, 257, -521, 244, -531, 261, -505, 497, -271, 511, -246, 520, -250, 536, -261, 496, -265, 507, -265, 507, -257, 511, -274, 492, -269, 524, -248, 514, -261, 497,
[17:55:43.841][I][remote.raw:035]:   -266, 524, -261, 495, -269, 512, -247, 516, -265, 264, -492, 539, -242, 523, -262, 498, -245, 533, -248, 516, -260, 524, -240, 266, -501, 261, -509, 535, -253, 268, -502, 253, -520, 516, -240, 266, -500, 268, -523, 515, -247, 515
[17:55:43.880][I][remote.raw:026]: Received Raw: -515, 512, -261, 259, -494, 535, -242, 260, -508, 265, -521, 270, -498, 522, -255, 505, -266, 251, -512, 263, -499, 270, -499, 287, -498, 513, -267, 504, -256, 524, -244, 274, -488, 516, -259, 258, -526, 510, -265, 237, -509, 532, -263,
[17:55:43.903][I][remote.raw:026]:   500, -244, 535, -246, 515, -262, 253, -504, 289, -502, 260, -506, 508, -258, 271, -500, 283, -490, 267, -511, 246, -518, 521, -264, 498, -244, 534, -247, 517, -261, 525, -243, 529, -252, 523, -220, 546, -224, 535, -263, 524, -240, 505, -267, 507,
[17:55:43.913][I][remote.raw:035]:   -258, 510, -275, 517, -243, 527, -247, 513, -262, 251, -503, 523, -258, 524, -243, 528, -247, 513, -262, 523, -242, 524, -264, 242, -525, 262, -487, 543, -237, 253, -517, 262, -500, 523, -244, 283, -498, 267, -512, 513, -269, 501
[17:55:43.935][W][component:513]: remote_receiver took a long time for an operation (56 ms), max is 50 ms
[17:55:43.968][I][remote.raw:026]: Received Raw: -491, 522, -246, 265, -522, 512, -268, 229, -531, 263, -509, 239, -533, 509, -264, 500, -244, 283, -498, 268, -512, 246, -516, 263, -500, 531, -255, 524, -243, 527, -246, 262, -497, 513, -267, 266, -500, 532, -252, 270, -499, 523, -237,
[17:55:43.978][I][remote.raw:026]:   520, -268, 500, -250, 520, -245, 269, -522, 243, -531, 263, -505, 524, -244, 262, -507, 272, -495, 269, -497, 275, -508, 509, -265, 499, -269, 513, -247, 516, -262, 525, -242, 523, -264, 501, -244, 532, -247, 514, -261, 524, -242, 527, -253, 524,
[17:55:43.984][I][remote.raw:035]:   -243, 526, -247, 514, -252, 507, -264, 521, -268, 240, -523, 497, -245, 546, -224, 534, -262, 522, -244, 528, -226, 546, -243, 272, -489, 267, -510, 511, -265, 261, -510, 263, -511, 498, -250, 268, -524, 246, -514, 515, -270, 501
[17:55:44.035][I][remote.raw:026]: Received Raw: -496, 542, -224, 284, -491, 537, -242, 268, -502, 270, -499, 285, -499, 516, -238, 529, -265, 237, -508, 291, -496, 269, -499, 247, -518, 513, -270, 500, -250, 545, -220, 294, -489, 514, -259, 259, -524, 510, -265, 238, -508, 532, -263,
[17:55:44.035][I][remote.raw:026]:   507, -254, 517, -244, 529, -247, 264, -513, 242, -530, 240, -516, 532, -243, 261, -508, 260, -503, 290, -480, 292, -482, 538, -248, 513, -261, 524, -242, 525, -261, 499, -244, 534, -247, 515, -262, 524, -244, 527, -251, 520, -243, 523, -247, 514,
[17:55:44.066][I][remote.raw:035]:   -251, 533, -232, 528, -261, 504, -268, 500, -251, 268, -524, 520, -237, 520, -268, 501, -257, 518, -244, 531, -246, 514, -251, 258, -514, 268, -498, 535, -241, 261, -508, 262, -509, 534, -262, 235, -531, 235, -532, 508, -256, 516
[17:55:44.088][I][remote.raw:026]: Received Raw: -520, 516, -247, 263, -516, 512, -267, 269, -477, 296, -496, 264, -499, 516, -266, 496, -266, 268, -498, 266, -500, 268, -513, 246, -516, 534, -241, 531, -251, 523, -243, 273, -497, 514, -267, 252, -511, 522, -263, 243, -500, 540, -247,
[17:55:44.107][I][remote.raw:026]:   513, -262, 497, -268, 526, -251, 270, -496, 247, -516, 269, -497, 524, -257, 271, -502, 255, -515, 265, -507, 263, -497, 519, -266, 507, -257, 516, -244, 533, -246, 515, -261, 524, -242, 502, -275, 517, -243, 532, -247, 511, -263, 523, -242, 528,
[17:55:44.139][I][remote.raw:035]:   -251, 523, -244, 525, -248, 513, -252, 506, -264, 252, -517, 522, -254, 524, -244, 528, -247, 513, -253, 532, -232, 528, -239, 259, -519, 263, -502, 541, -244, 260, -498, 268, -512, 514, -267, 267, -496, 270, -501, 508, -261, 525
[17:55:44.161][W][component:513]: remote_receiver took a long time for an operation (73 ms), max is 60 ms
[17:55:44.179][I][remote.raw:026]: Received Raw: -515, 531, -236, 272, -500, 538, -225, 282, -493, 268, -500, 289, -478, 524, -244, 536, -246, 266, -516, 243, -532, 247, -515, 262, -500, 524, -243, 533, -247, 514, -262, 253, -502, 525, -257, 272, -501, 507, -261, 253, -529, 517, -241,
[17:55:44.186][I][remote.raw:026]:   525, -245, 516, -245, 519, -250, 261, -514, 268, -499, 273, -511, 522, -236, 271, -499, 287, -498, 243, -530, 263, -505, 507, -257, 525, -243, 530, -247, 514, -252, 508, -258, 529, -238, 529, -265, 506, -264, 507, -254, 518, -243, 529, -247, 513,
[17:55:44.210][I][remote.raw:035]:   -252, 533, -231, 529, -260, 505, -266, 505, -265, 261, -506, 510, -248, 515, -269, 524, -224, 535, -253, 508, -259, 528, -240, 260, -514, 264, -499, 525, -244, 279, -497, 268, -512, 516, -241, 261, -508, 265, -522, 497, -268, 524
[17:55:44.227][I][remote.raw:035]: Received Raw: 266, -500, 272, -510, 264, -510, 263, -512, 264, -497, 271, -500, 256, -525, 242, -504
[17:55:44.239][I][remote.raw:026]: Received Raw: -499, 545, -231, 280, -508, 514, -243, 268, -497, 296, -480, 274, -497, 537, -245, 525, -235, 273, -501, 255, -523, 243, -502, 289, -504, 498, -268, 513, -247, 517, -261, 253, -503, 517, -266, 268, -498, 519, -246, 266, -521, 514, -242,
[17:55:44.261][I][remote.raw:026]:   523, -264, 500, -244, 534, -223, 283, -514, 266, -511, 247, -514, 509, -267, 267, -498, 265, -498, 268, -512, 246, -516, 534, -242, 531, -225, 547, -219, 549, -224, 532, -263, 522, -243, 525, -235, 526, -244, 531, -247, 514, -262, 523, -243, 527,
[17:55:44.294][I][remote.raw:035]:   -251, 497, -268, 525, -224, 535, -253, 532, -233, 527, -239, 260, -516, 252, -506, 263, -532, 509, -265, 269, -497, 516, -247, 264, -491, 268, -528, 515, -242, 268, -497, 517, -245, 267, -522, 513, -240, 296, -475, 531, -254, 523
[17:55:44.317][W][component:513]: remote_receiver took a long time for an operation (137 ms), max is 80 ms
[17:55:44.345][W][remote_receiver.esp32:149]: Buffer overflow
[17:55:44.352][I][remote.raw:026]: Received Raw: -499, 544, -238, 254, -515, 535, -241, 268, -498, 266, -507, 272, -492, 513, -268, 501, -276, 270, -478, 275, -497, 267, -501, 289, -501, 500, -244, 535, -246, 517, -261, 253, -529, 515, -241, 268, -497, 520, -246, 267, -521, 514, -267,
[17:55:44.362][I][remote.raw:026]:   501, -256, 517, -244, 529, -247, 261, -517, 242, -529, 264, -505, 499, -268, 261, -498, 268, -512, 247, -514, 265, -512, 509, -266, 499, -268, 513, -245, 517, -262, 523, -243, 528, -253, 522, -243, 524, -248, 511, -263, 497, -267, 502, -275, 497,
[17:55:44.383][I][remote.raw:035]:   -245, 547, -224, 534, -262, 497, -268, 524, -235, 516, -245, 283, -509, 245, -516, 269, -494, 533, -240, 268, -497, 521, -245, 268, -514, 267, -512, 516, -242, 266, -498, 522, -245, 268, -522, 514, -267, 269, -474, 532, -255, 498
[17:55:44.416][I][remote.raw:026]: Received Raw: -492, 532, -244, 267, -498, 524, -244, 277, -498, 267, -511, 247, -512, 509, -266, 525, -244, 262, -508, 247, -518, 268, -498, 290, -474, 525, -244, 535, -246, 515, -261, 253, -503, 517, -266, 268, -497, 519, -246, 267, -522, 513, -240,
[17:55:44.423][I][remote.raw:026]:   528, -253, 523, -243, 525, -224, 284, -495, 267, -501, 288, -502, 500, -268, 260, -499, 268, -512, 246, -515, 265, -511, 510, -265, 500, -269, 513, -246, 515, -261, 524, -243, 528, -252, 522, -219, 548, -224, 535, -263, 497, -268, 502, -249, 521,
[17:55:44.450][I][remote.raw:035]:   -246, 545, -224, 535, -263, 495, -268, 500, -251, 521, -245, 269, -523, 243, -529, 263, -506, 524, -219, 284, -508, 523, -236, 253, -519, 251, -531, 508, -264, 270, -497, 516, -247, 263, -494, 538, -242, 267, -499, 524, -244, 530
[17:55:44.478][I][remote.raw:026]: Received Raw: -508, 520, -239, 260, -515, 512, -270, 267, -497, 270, -501, 254, -499, 539, -242, 523, -262, 244, -500, 287, -490, 268, -511, 247, -514, 509, -267, 509, -248, 518, -245, 267, -522, 513, -241, 257, -530, 509, -264, 269, -497, 515, -247,
[17:55:44.516][I][remote.raw:026]:   515, -262, 497, -268, 502, -275, 270, -478, 275, -497, 268, -498, 525, -257, 272, -502, 254, -515, 243, -528, 240, -518, 520, -265, 499, -244, 536, -246, 515, -261, 524, -242, 528, -252, 523, -219, 522, -251, 532, -263, 523, -243, 527, -225, 520,
[17:55:44.528][I][remote.raw:035]:   -245, 547, -225, 536, -253, 506, -265, 520, -241, 526, -245, 264, -521, 244, -513, 269, -495, 532, -243, 268, -497, 521, -246, 265, -522, 242, -530, 517, -241, 267, -499, 519, -246, 267, -522, 514, -241, 267, -502, 523, -245, 532
[17:55:44.550][I][remote.raw:026]: Received Raw: -508, 529, -262, 252, -500, 525, -256, 271, -499, 247, -517, 269, -496, 519, -265, 499, -269, 260, -499, 268, -514, 246, -515, 264, -512, 509, -265, 500, -269, 511, -246, 265, -521, 512, -242, 268, -501, 524, -244, 280, -497, 516, -265,
[17:55:44.572][I][remote.raw:026]:   496, -266, 524, -244, 515, -247, 265, -521, 243, -528, 247, -513, 521, -237, 271, -500, 286, -499, 242, -531, 263, -504, 498, -269, 513, -246, 517, -261, 524, -242, 523, -263, 499, -245, 534, -246, 514, -261, 525, -243, 528, -225, 547, -219, 547,
[17:55:44.595][I][remote.raw:035]:   -224, 535, -262, 497, -268, 501, -250, 521, -245, 547, -225, 284, -494, 268, -498, 274, -512, 524, -250, 270, -498, 518, -237, 253, -515, 264, -512, 507, -267, 267, -498, 518, -246, 266, -497, 539, -241, 267, -499, 524, -244, 531
Try 2:
[17:59:41.135][I][remote.raw:035]: Received Raw: 288, -496, 246, -515, 264, -513, 264, -511, 263, -510, 240, -532, 240, -509, 263, -508
[17:59:41.194][I][remote.raw:026]: Received Raw: -497, 514, -266, 252, -512, 523, -253, 268, -503, 252, -515, 242, -529, 515, -265, 508, -262, 235, -508, 260, -534, 240, -506, 268, -507, 537, -224, 534, -262, 497, -267, 267, -499, 523, -244, 277, -497, 514, -265, 253, -511, 509, -265,
[17:59:41.194][I][remote.raw:026]:   499, -269, 512, -247, 518, -261, 253, -526, 241, -514, 265, -512, 508, -266, 267, -498, 266, -496, 268, -512, 246, -516, 533, -241, 523, -247, 517, -245, 519, -250, 532, -240, 535, -263, 495, -268, 500, -249, 521, -245, 547, -224, 534, -262, 496,
[17:59:41.194][I][remote.raw:035]:   -267, 500, -277, 495, -269, 524, -247, 513, -252, 260, -509, 512, -260, 506, -268, 502, -275, 496, -268, 523, -248, 512, -262, 251, -501, 289, -501, 498, -269, 259, -509, 246, -516, 515, -264, 238, -536, 264, -496, 523, -244, 529
[17:59:41.194][I][remote.raw:026]: Received Raw: -513, 514, -265, 253, -512, 524, -252, 270, -498, 246, -516, 268, -498, 519, -265, 508, -255, 268, -508, 265, -496, 268, -511, 246, -517, 522, -254, 523, -243, 526, -224, 285, -490, 535, -240, 267, -502, 522, -245, 281, -511, 518, -236,
[17:59:41.200][I][remote.raw:026]:   521, -265, 507, -264, 507, -255, 269, -501, 255, -521, 243, -527, 497, -259, 271, -500, 257, -515, 267, -510, 247, -516, 523, -254, 520, -244, 526, -247, 514, -252, 507, -263, 521, -267, 498, -248, 519, -245, 544, -224, 534, -262, 496, -268, 501,
[17:59:41.211][I][remote.raw:035]:   -277, 495, -269, 523, -248, 512, -253, 505, -264, 252, -517, 521, -254, 522, -244, 527, -248, 512, -262, 497, -267, 528, -251, 270, -496, 244, -516, 513, -267, 266, -499, 268, -500, 507, -250, 260, -515, 268, -500, 521, -258, 524
[17:59:41.248][I][remote.raw:026]: Received Raw: -519, 513, -267, 267, -498, 524, -244, 276, -487, 267, -513, 245, -519, 522, -255, 517, -244, 278, -485, 268, -513, 245, -520, 261, -528, 497, -245, 535, -247, 514, -261, 253, -503, 523, -257, 270, -501, 508, -261, 252, -506, 522, -258,
[17:59:41.253][I][remote.raw:026]:   524, -244, 529, -247, 513, -261, 251, -503, 288, -501, 269, -497, 517, -247, 263, -493, 268, -501, 289, -500, 261, -508, 498, -270, 513, -246, 517, -261, 524, -240, 527, -254, 516, -244, 529, -248, 512, -262, 497, -267, 502, -276, 496, -245, 546,
[17:59:41.288][I][remote.raw:035]:   -224, 535, -262, 496, -267, 525, -251, 495, -269, 247, -521, 515, -267, 496, -264, 497, -270, 513, -246, 516, -261, 524, -242, 267, -501, 269, -500, 510, -249, 260, -517, 268, -499, 522, -256, 270, -500, 257, -522, 514, -267, 496
[17:59:41.316][I][remote.raw:026]: Received Raw: -516, 496, -269, 248, -523, 514, -267, 229, -533, 264, -496, 271, -500, 507, -250, 535, -262, 250, -497, 261, -527, 243, -522, 263, -510, 493, -264, 521, -267, 502, -255, 269, -503, 506, -252, 260, -509, 510, -268, 267, -499, 523, -244,
[17:59:41.332][I][remote.raw:026]:   526, -247, 513, -263, 496, -267, 266, -500, 268, -500, 256, -523, 514, -240, 267, -502, 270, -500, 285, -489, 266, -508, 510, -265, 506, -265, 508, -255, 523, -244, 527, -247, 512, -262, 497, -266, 500, -276, 517, -243, 526, -247, 512, -262, 497,
[17:59:41.364][I][remote.raw:035]:   -268, 502, -251, 521, -245, 520, -250, 533, -262, 251, -498, 523, -257, 524, -244, 526, -247, 514, -253, 507, -259, 529, -242, 266, -500, 270, -499, 511, -250, 260, -515, 269, -498, 522, -258, 267, -508, 264, -497, 515, -264, 496
[17:59:41.404][I][remote.raw:026]: Received Raw: -516, 495, -269, 247, -522, 516, -266, 241, -503, 269, -499, 288, -498, 513, -267, 501, -255, 269, -501, 254, -515, 242, -528, 241, -518, 522, -254, 516, -243, 531, -248, 263, -514, 511, -238, 260, -518, 523, -254, 267, -482, 540, -247,
[17:59:41.413][I][remote.raw:026]:   512, -262, 497, -266, 500, -277, 243, -507, 285, -486, 267, -509, 510, -264, 239, -533, 239, -509, 291, -495, 271, -498, 519, -238, 521, -267, 498, -249, 519, -245, 521, -250, 535, -261, 496, -267, 499, -275, 495, -270, 497, -250, 534, -263, 495,
[17:59:41.433][I][remote.raw:035]:   -268, 501, -249, 521, -245, 520, -250, 533, -262, 250, -499, 523, -256, 523, -244, 527, -248, 514, -253, 506, -258, 505, -264, 261, -515, 254, -506, 530, -252, 270, -497, 245, -512, 511, -267, 266, -498, 268, -500, 510, -250, 535
[17:59:41.472][I][remote.raw:026]: Received Raw: -518, 523, -247, 264, -496, 516, -263, 253, -517, 262, -501, 269, -502, 538, -224, 534, -263, 250, -497, 261, -503, 268, -522, 262, -497, 514, -264, 496, -266, 524, -246, 262, -507, 523, -262, 226, -519, 532, -242, 267, -498, 519, -246,
[17:59:41.478][I][remote.raw:026]:   518, -251, 534, -262, 495, -268, 265, -497, 269, -500, 255, -522, 513, -240, 266, -501, 268, -500, 285, -497, 243, -531, 497, -259, 525, -244, 527, -247, 513, -252, 508, -257, 531, -238, 530, -241, 507, -286, 483, -276, 495, -269, 500, -273, 511,
[17:59:41.510][I][remote.raw:035]:   -262, 496, -267, 501, -275, 495, -245, 547, -224, 261, -517, 512, -267, 499, -277, 495, -269, 499, -273, 512, -262, 495, -267, 265, -499, 268, -500, 509, -250, 259, -515, 268, -499, 521, -257, 269, -501, 256, -522, 514, -267, 500
[17:59:41.532][I][remote.raw:035]: Received Raw: 255, -513, 243, -530, 241, -519, 262, -500, 268, -524, 262, -497, 244, -532, 247, -516
[17:59:41.548][I][remote.raw:026]: Received Raw: -516, 516, -268, 239, -523, 496, -268, 248, -521, 243, -532, 246, -516, 522, -254, 516, -244, 250, -511, 268, -509, 265, -496, 265, -514, 510, -265, 507, -256, 522, -244, 277, -496, 515, -264, 252, -513, 522, -252, 242, -523, 521, -262,
[17:59:41.554][I][remote.raw:026]:   494, -267, 497, -275, 494, -246, 270, -521, 243, -530, 263, -503, 498, -269, 260, -496, 268, -513, 246, -516, 265, -513, 509, -264, 498, -269, 512, -247, 518, -261, 498, -266, 525, -253, 495, -269, 501, -273, 513, -253, 508, -259, 506, -264, 506,
[17:59:41.587][I][remote.raw:035]:   -265, 507, -257, 515, -245, 533, -247, 514, -261, 498, -262, 263, -501, 287, -501, 236, -533, 509, -255, 269, -502, 506, -260, 253, -529, 262, -503, 510, -246, 263, -510, 508, -251, 261, -511, 510, -263, 262, -515, 521, -252, 516
[17:59:41.609][I][remote.raw:026]: Received Raw: -497, 545, -237, 253, -516, 522, -255, 270, -497, 246, -516, 268, -497, 523, -256, 517, -244, 278, -497, 268, -510, 263, -505, 269, -496, 518, -246, 515, -261, 523, -242, 267, -499, 524, -244, 277, -497, 516, -266, 253, -512, 498, -251,
[17:59:41.633][I][remote.raw:026]:   520, -244, 520, -250, 534, -261, 251, -499, 274, -509, 264, -485, 532, -264, 243, -524, 263, -497, 244, -533, 263, -505, 499, -269, 511, -246, 515, -261, 524, -241, 528, -252, 518, -243, 527, -224, 536, -262, 496, -268, 501, -250, 522, -245, 519,
[17:59:41.653][I][remote.raw:035]:   -250, 534, -263, 495, -268, 502, -249, 520, -246, 519, -251, 260, -515, 268, -499, 274, -508, 509, -264, 269, -497, 517, -246, 264, -518, 243, -527, 497, -258, 270, -501, 508, -252, 259, -512, 536, -240, 260, -515, 521, -252, 517
[17:59:41.683][I][remote.raw:026]: Received Raw: -508, 534, -225, 258, -513, 536, -240, 259, -515, 263, -499, 269, -500, 537, -225, 534, -263, 251, -498, 274, -511, 264, -496, 269, -501, 510, -261, 525, -243, 527, -252, 267, -483, 538, -224, 283, -490, 536, -239, 260, -516, 523, -254,
[17:59:41.698][I][remote.raw:026]:   518, -243, 525, -247, 513, -252, 260, -510, 265, -497, 264, -512, 531, -243, 269, -497, 267, -499, 267, -511, 247, -512, 534, -243, 527, -244, 511, -246, 516, -262, 525, -243, 525, -236, 516, -244, 535, -247, 515, -261, 523, -243, 530, -227, 522,
[17:59:41.736][I][remote.raw:035]:   -244, 547, -224, 534, -263, 497, -270, 501, -249, 520, -245, 267, -514, 267, -511, 247, -515, 524, -253, 271, -479, 528, -263, 251, -499, 289, -477, 525, -243, 281, -497, 515, -267, 253, -512, 523, -227, 295, -498, 519, -238, 521
[17:59:41.754][I][remote.raw:026]: Received Raw: -513, 524, -244, 278, -498, 515, -267, 252, -507, 263, -509, 262, -509, 507, -265, 500, -244, 283, -498, 267, -511, 246, -514, 263, -500, 525, -244, 531, -247, 513, -262, 252, -501, 517, -267, 270, -498, 519, -246, 263, -495, 536, -243,
[17:59:41.776][I][remote.raw:026]:   530, -252, 522, -220, 546, -224, 283, -493, 267, -501, 289, -476, 525, -244, 284, -499, 267, -512, 246, -513, 264, -514, 524, -226, 522, -246, 544, -224, 533, -263, 522, -244, 503, -249, 521, -245, 544, -224, 533, -263, 496, -268, 525, -234, 527,
[17:59:41.800][I][remote.raw:035]:   -243, 530, -223, 534, -263, 521, -244, 502, -250, 522, -245, 269, -522, 243, -504, 273, -511, 532, -242, 269, -499, 518, -246, 263, -497, 268, -501, 542, -241, 270, -499, 518, -246, 263, -495, 537, -243, 267, -502, 524, -243, 527
[17:59:41.838][I][remote.raw:026]: Received Raw: -510, 523, -255, 270, -502, 506, -252, 258, -512, 265, -497, 273, -510, 509, -264, 498, -269, 260, -507, 246, -516, 246, -517, 266, -516, 521, -253, 495, -269, 500, -273, 239, -516, 513, -266, 267, -499, 522, -244, 278, -497, 515, -265,
[17:59:41.844][I][remote.raw:026]:   495, -266, 499, -270, 513, -246, 267, -519, 243, -526, 241, -516, 509, -266, 267, -497, 267, -497, 268, -513, 246, -516, 509, -266, 500, -271, 513, -247, 517, -261, 498, -266, 526, -253, 496, -269, 500, -273, 512, -262, 496, -267, 500, -259, 525,
[17:59:41.876][I][remote.raw:035]:   -244, 529, -248, 514, -261, 499, -267, 501, -277, 491, -268, 248, -513, 267, -509, 242, -518, 535, -240, 261, -508, 521, -248, 265, -497, 268, -513, 515, -267, 239, -524, 495, -269, 249, -512, 516, -259, 260, -522, 510, -265, 508
[17:59:41.887][I][remote.raw:026]: Received Raw: -518, 495, -268, 248, -513, 515, -259, 260, -497, 266, -515, 263, -501, 514, -269, 511, -246, 265, -521, 243, -524, 241, -517, 262, -500, 522, -244, 533, -248, 515, -262, 251, -502, 518, -265, 267, -498, 518, -246, 266, -520, 513, -241,
[17:59:41.920][I][remote.raw:026]:   526, -253, 497, -269, 501, -273, 238, -537, 241, -525, 241, -519, 520, -254, 267, -507, 263, -496, 268, -510, 263, -504, 499, -269, 513, -246, 518, -252, 534, -235, 521, -267, 500, -248, 519, -269, 497, -251, 535, -262, 496, -266, 499, -275, 495,
[17:59:41.952][I][remote.raw:035]:   -269, 499, -250, 536, -261, 497, -264, 507, -265, 507, -257, 266, -507, 264, -509, 254, -521, 514, -240, 266, -500, 523, -245, 280, -509, 244, -515, 514, -268, 266, -496, 521, -244, 249, -514, 516, -264, 252, -516, 522, -253, 496
Try 3:
[18:00:34.384][I][remote.raw:035]: Received Raw: 298, -482, 247, -519, 268, -497, 275, -512, 263, -497, 270, -499, 284, -490, 267, -511
[18:00:34.395][I][remote.raw:026]: Received Raw: -495, 526, -262, 250, -499, 518, -267, 268, -498, 266, -499, 268, -512, 515, -268, 499, -248, 265, -499, 269, -514, 246, -516, 265, -515, 522, -253, 523, -243, 525, -247, 262, -515, 512, -239, 260, -518, 522, -255, 267, -507, 514, -247,
[18:00:34.395][I][remote.raw:026]:   515, -251, 534, -231, 529, -265, 269, -501, 269, -498, 264, -498, 516, -265, 253, -510, 263, -499, 269, -499, 286, -499, 514, -267, 496, -265, 500, -269, 513, -246, 517, -261, 524, -241, 528, -254, 522, -243, 526, -247, 512, -253, 533, -233, 529,
[18:00:34.395][I][remote.raw:035]:   -239, 530, -241, 531, -262, 500, -244, 533, -247, 264, -495, 539, -242, 527, -252, 517, -243, 529, -248, 514, -261, 498, -268, 267, -497, 270, -500, 511, -251, 260, -512, 266, -500, 534, -268, 240, -498, 269, -506, 536, -241, 515
[18:00:34.395][I][remote.raw:026]: Received Raw: -504, 521, -262, 235, -508, 523, -245, 282, -499, 267, -512, 246, -517, 520, -264, 499, -244, 283, -498, 268, -512, 246, -514, 265, -514, 523, -253, 522, -244, 525, -247, 262, -495, 539, -240, 261, -514, 523, -236, 261, -507, 537, -245,
[18:00:34.405][I][remote.raw:026]:   515, -246, 518, -261, 524, -242, 266, -501, 270, -500, 286, -497, 514, -267, 252, -508, 263, -510, 263, -509, 239, -509, 533, -263, 499, -245, 535, -247, 514, -261, 522, -242, 528, -253, 523, -243, 524, -248, 514, -262, 498, -268, 526, -234, 525,
[18:00:34.421][I][remote.raw:035]:   -244, 529, -247, 515, -252, 533, -231, 528, -267, 229, -533, 522, -251, 496, -268, 525, -248, 511, -253, 506, -265, 522, -241, 261, -508, 264, -522, 523, -243, 274, -488, 268, -510, 509, -265, 261, -514, 254, -506, 507, -259, 533
[18:00:34.460][I][remote.raw:026]: Received Raw: -517, 492, -269, 249, -513, 514, -260, 259, -524, 240, -517, 262, -500, 538, -245, 514, -246, 266, -515, 243, -533, 263, -505, 268, -497, 518, -247, 515, -261, 524, -242, 267, -501, 523, -244, 279, -499, 515, -267, 253, -513, 523, -234,
[18:00:34.466][I][remote.raw:026]:   526, -244, 531, -247, 513, -262, 251, -502, 273, -510, 263, -511, 508, -265, 269, -498, 264, -499, 268, -513, 246, -514, 535, -242, 524, -246, 515, -245, 518, -251, 533, -263, 496, -267, 502, -250, 520, -246, 546, -225, 534, -263, 496, -268, 525,
[18:00:34.498][I][remote.raw:035]:   -236, 516, -268, 512, -247, 517, -261, 524, -241, 267, -501, 523, -244, 533, -246, 514, -262, 523, -243, 526, -252, 523, -243, 274, -498, 244, -533, 516, -241, 268, -497, 269, -506, 527, -262, 251, -498, 273, -511, 522, -253, 522
[18:00:34.543][I][remote.raw:026]: Received Raw: -497, 542, -237, 252, -518, 523, -255, 270, -498, 248, -519, 269, -495, 534, -241, 525, -247, 265, -506, 274, -495, 268, -499, 288, -500, 499, -268, 514, -246, 517, -249, 261, -515, 513, -267, 267, -499, 522, -243, 280, -499, 515, -266,
[18:00:34.554][I][remote.raw:026]:   521, -241, 526, -245, 514, -246, 267, -521, 243, -530, 247, -513, 508, -267, 267, -497, 266, -498, 269, -511, 265, -498, 518, -266, 524, -244, 515, -246, 517, -261, 524, -241, 528, -254, 523, -244, 525, -248, 513, -262, 523, -242, 527, -252, 517,
[18:00:34.566][I][remote.raw:035]:   -243, 528, -247, 514, -261, 499, -268, 524, -235, 270, -500, 538, -225, 534, -262, 496, -268, 527, -251, 497, -268, 523, -247, 262, -492, 269, -527, 516, -242, 267, -498, 267, -499, 516, -259, 258, -526, 241, -517, 522, -255, 524
[18:00:34.611][I][remote.raw:026]: Received Raw: -497, 543, -237, 252, -516, 533, -241, 268, -497, 268, -523, 244, -515, 515, -268, 500, -258, 270, -501, 256, -525, 242, -529, 247, -514, 523, -253, 523, -243, 526, -248, 262, -518, 512, -242, 266, -501, 525, -244, 280, -498, 516, -265,
[18:00:34.617][I][remote.raw:026]:   521, -242, 524, -245, 516, -245, 268, -520, 243, -530, 247, -512, 509, -266, 267, -498, 266, -497, 269, -513, 246, -517, 535, -241, 525, -246, 517, -246, 519, -250, 533, -263, 496, -268, 501, -276, 496, -268, 523, -248, 511, -262, 522, -242, 527,
[18:00:34.643][I][remote.raw:035]:   -252, 522, -244, 525, -247, 513, -253, 507, -259, 259, -525, 510, -267, 501, -248, 518, -246, 545, -224, 534, -262, 496, -267, 267, -499, 269, -500, 511, -251, 284, -489, 266, -525, 511, -268, 239, -523, 270, -498, 519, -239, 533
[18:00:34.686][I][remote.raw:026]: Received Raw: -520, 513, -242, 267, -500, 524, -244, 281, -496, 267, -511, 246, -517, 522, -255, 524, -244, 275, -487, 268, -512, 246, -519, 262, -526, 498, -268, 510, -247, 516, -261, 253, -530, 496, -258, 271, -500, 509, -250, 261, -516, 539, -242,
[18:00:34.691][I][remote.raw:026]:   525, -235, 525, -243, 534, -247, 264, -520, 243, -524, 246, -514, 533, -241, 268, -498, 267, -499, 267, -513, 246, -517, 533, -242, 525, -247, 517, -245, 519, -251, 535, -262, 497, -268, 501, -250, 521, -245, 546, -247, 513, -262, 496, -267, 526,
[18:00:34.709][I][remote.raw:035]:   -252, 495, -269, 525, -247, 513, -253, 507, -259, 259, -525, 510, -268, 499, -247, 519, -245, 520, -250, 534, -262, 496, -268, 266, -500, 269, -499, 510, -250, 260, -515, 268, -498, 534, -267, 240, -524, 269, -499, 519, -237, 520
[18:00:34.731][I][remote.raw:035]: Received Raw: 253, -515, 243, -531, 247, -515, 263, -499, 268, -500, 287, -498, 244, -531, 247, -513
[18:00:34.758][I][remote.raw:026]: Received Raw: -509, 537, -247, 264, -519, 513, -241, 267, -501, 270, -499, 285, -497, 514, -265, 497, -265, 267, -497, 266, -496, 269, -513, 246, -517, 535, -241, 525, -247, 515, -246, 267, -519, 515, -267, 241, -501, 523, -244, 283, -497, 516, -263,
[18:00:34.765][I][remote.raw:026]:   521, -241, 531, -261, 508, -252, 266, -508, 262, -509, 252, -514, 512, -262, 237, -516, 265, -514, 262, -499, 268, -499, 513, -273, 513, -261, 497, -267, 500, -276, 496, -269, 525, -247, 514, -253, 506, -258, 529, -238, 530, -264, 508, -262, 498,
[18:00:34.797][I][remote.raw:035]:   -268, 511, -247, 516, -260, 524, -240, 526, -254, 522, -244, 249, -521, 244, -533, 246, -517, 522, -254, 267, -509, 514, -248, 263, -493, 268, -527, 495, -257, 269, -500, 512, -250, 262, -515, 513, -266, 266, -500, 521, -244, 532
[18:00:34.819][I][remote.raw:026]: Received Raw: -512, 521, -257, 271, -501, 507, -251, 260, -515, 267, -499, 288, -501, 497, -269, 512, -246, 266, -520, 243, -530, 262, -480, 294, -495, 516, -247, 518, -261, 523, -242, 266, -501, 523, -244, 279, -486, 516, -263, 253, -517, 522, -255,
[18:00:34.854][I][remote.raw:026]:   521, -244, 527, -248, 513, -252, 260, -509, 266, -496, 266, -516, 522, -255, 267, -483, 287, -486, 268, -513, 245, -517, 510, -266, 523, -246, 517, -246, 519, -250, 535, -262, 496, -267, 499, -275, 495, -269, 499, -273, 512, -262, 497, -267, 527,
[18:00:34.871][I][remote.raw:035]:   -251, 496, -269, 500, -273, 514, -252, 507, -258, 530, -240, 261, -515, 262, -499, 267, -523, 514, -248, 262, -493, 538, -241, 266, -501, 270, -499, 512, -273, 238, -516, 513, -267, 265, -501, 521, -244, 280, -509, 493, -288, 494
[18:00:34.903][I][remote.raw:026]: Received Raw: -516, 498, -268, 261, -497, 516, -265, 252, -516, 262, -499, 270, -499, 539, -224, 535, -262, 251, -499, 288, -502, 268, -498, 264, -509, 519, -237, 521, -267, 499, -249, 268, -498, 545, -237, 252, -517, 522, -255, 270, -502, 506, -265,
[18:00:34.924][I][remote.raw:026]:   512, -262, 498, -268, 501, -251, 268, -523, 244, -516, 268, -497, 523, -256, 267, -507, 264, -507, 253, -516, 243, -528, 509, -265, 506, -264, 508, -255, 523, -244, 526, -248, 512, -262, 498, -267, 524, -261, 498, -245, 533, -247, 515, -261, 523,
[18:00:34.952][I][remote.raw:035]:   -242, 528, -252, 523, -243, 523, -248, 511, -262, 498, -267, 266, -499, 269, -500, 258, -522, 514, -266, 228, -534, 499, -275, 270, -497, 244, -516, 514, -268, 266, -498, 521, -244, 275, -498, 514, -265, 252, -510, 510, -264, 497
[18:00:34.975][I][remote.raw:026]: Received Raw: -510, 517, -246, 266, -521, 514, -240, 267, -501, 270, -499, 287, -498, 515, -267, 502, -255, 271, -500, 254, -521, 243, -528, 262, -504, 523, -245, 513, -246, 518, -251, 260, -515, 514, -268, 267, -499, 524, -243, 276, -486, 516, -264,
[18:00:34.997][I][remote.raw:026]:   521, -268, 498, -248, 516, -245, 269, -521, 243, -531, 263, -504, 522, -246, 262, -497, 268, -512, 246, -519, 261, -501, 523, -244, 535, -246, 516, -261, 523, -241, 527, -254, 522, -243, 526, -248, 512, -260, 498, -268, 526, -252, 517, -241, 528,
[18:00:35.008][I][remote.raw:035]:   -247, 513, -262, 522, -243, 526, -252, 520, -243, 524, -247, 262, -493, 268, -501, 288, -503, 497, -269, 260, -498, 515, -264, 252, -515, 262, -500, 523, -243, 282, -497, 515, -266, 252, -511, 508, -266, 267, -497, 518, -247, 518
[18:00:35.053][I][remote.raw:026]: Received Raw: -516, 512, -242, 267, -501, 524, -244, 280, -496, 267, -512, 246, -517, 523, -254, 521, -244, 248, -513, 268, -509, 265, -496, 265, -515, 521, -254, 516, -244, 529, -247, 263, -513, 514, -266, 228, -535, 497, -250, 267, -522, 520, -236,
[18:00:35.064][I][remote.raw:026]:   521, -264, 507, -264, 508, -254, 267, -507, 263, -509, 252, -515, 513, -265, 240, -528, 242, -524, 263, -498, 267, -510, 522, -234, 524, -245, 532, -247, 514, -261, 498, -267, 525, -252, 496, -269, 526, -247, 513, -261, 497, -266, 501, -277, 495,
[18:00:35.086][I][remote.raw:035]:   -269, 524, -248, 512, -262, 496, -267, 501, -277, 494, -268, 248, -514, 267, -509, 265, -496, 534, -241, 261, -509, 509, -259, 269, -500, 259, -523, 514, -267, 241, -502, 533, -253, 270, -502, 505, -261, 252, -503, 522, -257, 510
[18:00:35.099][I][remote.raw:026]: Received Raw: -518, 518, -247, 266, -520, 513, -240, 266, -501, 260, -509, 268, -523, 515, -248, 511, -241, 262, -516, 268, -499, 288, -501, 268, -497, 515, -247, 516, -261, 523, -242, 266, -500, 522, -244, 278, -511, 491, -263, 253, -517, 523, -255,
[18:00:35.131][I][remote.raw:026]:   523, -244, 524, -247, 512, -262, 250, -501, 290, -476, 269, -524, 514, -247, 264, -493, 267, -523, 241, -514, 265, -512, 509, -265, 499, -268, 514, -246, 515, -261, 523, -241, 527, -253, 522, -244, 525, -247, 512, -262, 497, -267, 500, -276, 517,
[18:00:35.155][I][remote.raw:035]:   -244, 526, -248, 510, -241, 535, -262, 496, -268, 500, -250, 268, -523, 245, -514, 246, -519, 521, -256, 270, -502, 506, -261, 252, -503, 288, -503, 524, -243, 261, -508, 521, -237, 253, -516, 533, -242, 268, -497, 519, -246, 518
I think you might have been right on the truncated parts? This seems to now work with this code!
Adding below for future people's reference! Massive thank you for helping me out with this; zero chance I would have worked this out.
            288, -496, 246, -515, 264, -513, 264, -511, 263, -510, 240, -532, 240, -509, 263, -508,
            4356, -497, 514, -266, 252, -512, 523, -253, 268, -503, 252, -515, 242, -529, 515, -265,
            267, -499, 523, -244, 277, -497, 514, -265, 253, -511, 509, -265, 499, -269, 512, -247,
            500, -249, 521, -245, 547, -224, 534, -262, 496, -267, 500, -277, 495, -269, 524, -247,
            523, -244, 529, -4341, 4376, -513, 514, -265, 253, -512, 524, -252, 270, -498, 246, -516,
            521, -267, 498, -248, 519, -245, 544, -224, 534, -262, 496, -268, 501, -277, 495, -269,
            260, -515, 268, -500, 521, -258, 524, -4341, 4376, -519, 513, -267, 267, -498, 524, -244,
            252, -506, 522, -258, 524, -244, 529, -247, 513, -261, 251, -503, 288, -501, 269, -497,
            546, -224, 535, -262, 496, -267, 525, -251, 495, -269, 247, -521, 515, -267, 496, -264,
            268, -499, 522, -256, 270, -500, 257, -522, 514, -267, 496, -4341, 4376, -516, 496, -269,
            260, -509, 510, -268, 267, -499, 523, -244, 526, -247, 513, -263, 496, -267, 266, -500,
            526, -247, 512, -262, 497, -268, 502, -251, 521, -245, 520, -250, 533, -262, 251, -498,
            511, -250, 260, -515, 269, -498, 522, -258, 267, -508, 264, -497, 515, -264, 496, -4341,
            4376, -516, 495, -269, 247, -522, 516, -266, 241, -503, 269, -499, 288, -498, 513, -267,
            263, -514, 511, -238, 260, -518, 523, -254, 267, -482, 540, -247, 512, -262, 497, -266,
            499, -275, 495, -270, 497, -250, 534, -263, 495, -268, 501, -249, 521, -245, 520, -250,
            510, -250, 535, -4341, 4376, -518, 523, -247, 264, -496, 516, -263, 253, -517, 262, -501,
            531, -238, 530, -241, 507, -286, 483, -276, 495, -269, 500, -273, 511, -262, 496, -267,
            269, -501, 256, -522, 514, -267, 500, -4341, 255, -513, 243, -530, 241, -519, 262, -500,
            268, -524, 262, -497, 244, -532, 247, -516, 4356, -516, 516, -268, 239, -523, 496, -268,
            242, -523, 521, -262, 494, -267, 497, -275, 494, -246, 270, -521, 243, -530, 263, -503,
            506, -265, 507, -257, 515, -245, 533, -247, 514, -261, 498, -262, 263, -501, 287, -501,
            508, -251, 261, -511, 510, -263, 262, -515, 521, -252, 516, -4341, 4376, -497, 545, -237,
            277, -497, 516, -266, 253, -512, 498, -251, 520, -244, 520, -250, 534, -261, 251, -499,
            501, -250, 522, -245, 519, -250, 534, -263, 495, -268, 502, -249, 520, -246, 519, -251,
            497, -258, 270, -501, 508, -252, 259, -512, 536, -240, 260, -515, 521, -252, 517, -4341,
            4376, -508, 534, -225, 258, -513, 536, -240, 259, -515, 263, -499, 269, -500, 537, -225,
            267, -483, 538, -224, 283, -490, 536, -239, 260, -516, 523, -254, 518, -243, 525, -247,
            535, -247, 515, -261, 523, -243, 530, -227, 522, -244, 547, -224, 534, -263, 497, -270,
            519, -238, 521, -4341, 4376, -513, 524, -244, 278, -498, 515, -267, 252, -507, 263, -509,
            503, -249, 521, -245, 544, -224, 533, -263, 496, -268, 525, -234, 527, -243, 530, -223,
            537, -243, 267, -502, 524, -243, 527, -4341, 4376, -510, 523, -255, 270, -502, 506, -252,
            278, -497, 515, -265, 495, -266, 499, -270, 513, -246, 267, -519, 243, -526, 241, -516,
            525, -244, 529, -248, 514, -261, 499, -267, 501, -277, 491, -268, 248, -513, 267, -509,
            495, -269, 249, -512, 516, -259, 260, -522, 510, -265, 508, -4341, 4376, -518, 495, -268,
            267, -498, 518, -246, 266, -520, 513, -241, 526, -253, 497, -269, 501, -273, 238, -537,
            496, -266, 499, -275, 495, -269, 499, -250, 536, -261, 497, -264, 507, -265, 507, -257,
            514, -268, 266, -496, 521, -244, 249, -514, 516, -264, 252, -516, 522, -253, 496, -4341
You are welcome.
I think the best strategy generally with classic esp32 is to first capture with max idle (32ms) to see the frame separators, gap lengths. Then adjust idle accordingly to capture separate frames. Otherwise long signal with many repeats is running esp to memory problems.
@wannaautomate Any chance you can share your final YAML config file?
I also have some issue to TX on my side :blush:
Thank you!
Hey sorry for the slow response. I have two completely dedicated esp32 + CC1101 modules wired as when testing I found there were issues getting the CC1101 unit into TX mode even though no errors were thrown I used the RX module to confirm no TX was sent. I'd also seen other reports of this so went with a dedicated RX/TX setup albeit now I have the signals I don't need the RX and could have swapped out the builds if I only had one but used it to confirm / compare the real signal + the RX signal.
This could well be user error as I went through lots of different builds.
TX config:
esphome:
esp32:
  board: esp32dev
wifi:
  ssid: !secret wifi_ssid
logger:
api:
  encryption:
    key: "x"
ota:
  - platform: esphome
    password: "x"
spi:
  clk_pin: GPIO18
  mosi_pin: GPIO23
  miso_pin: GPIO19
cc1101:
  cs_pin: GPIO5
remote_transmitter:
  pin: GPIO4
  rmt_symbols: 512
  on_transmit:
    then:
      - cc1101.begin_tx
  on_complete:
    then:
      - cc1101.begin_rx
button:
  - platform: restart
    on_press:
          code: [
    on_press:
          code: [
REMOVED - Char limit
    on_press:
          code: [
    on_press:
          code: [
RX config
esphome:
esp32:
  board: esp32dev
wifi:
logger:
api:
  encryption:
    key: "x"
ota:
  - platform: esphome
    password: "x"
spi:
  clk_pin: GPIO18
  mosi_pin: GPIO23
  miso_pin: GPIO19
cc1101:
  cs_pin: GPIO5
remote_receiver:
  pin: GPIO2
  dump: raw
  filter: 150us
  idle: 3ms
  buffer_size: 2kb
