Issue with Color Threshold Configuration in ApexCharts Card
I’m having an issue with configuring my ApexCharts card. I want the chart to change its colors based on temperature values. Specifically, if both sensors show 60°C, the entire chart should be red. If one sensor shows 40°C and the other shows 60°C, I expect a color difference between the two values based on the color_threshold feature.
Unfortunately, the color threshold is not being applied at all with my current configuration. Has anyone encountered this issue or knows how to properly configure color thresholds for this scenario?
Thank you for your help!
type: custom:apexcharts-card
graph_span: 0.01m
header:
  show: true
  title: Pufferspeicher Temperatur
  show_states: true
  colorize_states: true
apex_config:
  chart:
    height: 300px
  legend:
    show: false
  xaxis:
    labels:
      show: false
      format: HH:mm
  tooltip:
    enabled: true
  stroke:
    width: 0
  fill:
    type: gradient
yaxis:
  - id: first
    decimals: 1
    min: 0
    max: auto
    show: false
    apex_config:
      title:
        text: Temperatur (°C)
      tickAmount: 5
      forceNiceScale: true
all_series_config:
  type: area
  show:
    datalabels: false
  curve: smooth
series:
  - entity: sensor.pufferspeicher_temperature
    yaxis_id: first
    fill_raw: last
    color: ""
    color_threshold:
      - value: 20
        color: "#0000FF"
      - value: 40
        color: "#00BFFF"
      - value: 50
        color: "#FFFF00"
      - value: 57
        color: "#FF0000"
  - entity: sensor.pufferspeicher_temperature_2
    yaxis_id: first
    fill_raw: last
    color: ""
    color_threshold:
      - value: 20
        color: "#0000FF"
      - value: 40
        color: "#00BFFF"
      - value: 50
        color: "#FFFF00"
      - value: 60
        color: "#FF0000"
experimental:
  disable_config_validation: true
card_mod:
  style: |
    div#header__title {
      font-size: 18px;
      margin-top: 0.25rem;
      margin-bottom: 0.5rem;
