Issue with Dwains Unraid Dashboard Blueprint
Im having some issues getting the dwains dashboard unraid page working. I have glances and unraid api setup on the unraid server and successfully sending the data to home assistant through the glances integration and MQTT broker. I can use mqtt functions and are getting accurate numbers through the integrations in Home assistant.
I am having an issue feeding this data into the Dwains Dashboard blueprint found here when I copy the yaml code and save as the instructions advise, I get messages saying “Entity not available: undefined” which tracks as I don’t see the entitities being referenced in the yaml code but I also don’t how to define them either.
