Issue with Home Assistant Green after restart
Hi all
Newbee here, thanks for your help! I bought a Home Assitant Green, thought I could plug it in and use it. It started succesfully the first time, but after restarting, It gets corrupted, I get this:
I can then flash it with an SD card, after which it starts correctly, but after loosing power I have the same issue again. I even installed a CR2032 battery, does not help. Powering it down correctly before removing power also not. Any Idea what this is?
I got this from the HA support, I think it helped. Got some error messages after the wipe first, but after restarting the isses were gone:
Can you make sure the Green is connected to your local network and has access to the internet, and then try the command ha os datadisk wipe
You will then be prompted to enter Yes to confirm.
If this command is functional in the current state, you may see the console quit, and the system may restart more than one time. It is best to walk away for about 10 minutes and then check back in. If you see the “welcome” screen which displays the IPv4 address, you can then use that IP address in a browser’s address bar from another device on your local network with the port :8123 at the end. So for example, 192.168.1.50:8123 (but using the IP address shown on the Welcome page).
