My Voice Assistant Preview Edition seems to be working intermittently. The actual assistant is fine, I can type what is the weather to it in the text chat but when it comes to the home assistant preview edition it seems there are some errors when piper processes the text to speech voice. (I’m running on a pi4).
As far as i can see, whisper, open wake word seem fine so piper may be the issue. I know python as a language but not knowing piper i can’t debug myself and was hoping someone else could help me as my setup is as basic as it comes.
Here is the main error log, piper log and whisper log.
Logger: homeassistant
Source: components/wyoming/tts.py:126
First occurred: 11:08:50 (6 occurrences)
Last logged: 11:34:27
Error doing job: Exception in callback SpeechManager._async_get_tts_audio.<locals>.handle_error() at /usr/src/homeassistant/homeassistant/components/tts/__init__.py:844 (None)
File "/usr/local/lib/python3.13/asyncio/events.py", line 89, in _run
self._context.run(self._callback, *self._args)
File "/usr/src/homeassistant/homeassistant/components/tts/__init__.py", line 846, in handle_error
if audio_task.exception():
File "/usr/src/homeassistant/homeassistant/components/tts/__init__.py", line 786, in get_tts_data
extension, data = await engine_instance.internal_async_get_tts_audio(
message, language, options
File "/usr/src/homeassistant/homeassistant/components/tts/__init__.py", line 492, in internal_async_get_tts_audio
return await self.async_get_tts_audio(
message=message, language=language, options=options
File "/usr/src/homeassistant/homeassistant/components/wyoming/tts.py", line 126, in async_get_tts_audio
event = await client.read_event()
File "/usr/local/lib/python3.13/site-packages/wyoming/client.py", line 25, in read_event
return await async_read_event(self._reader)
File "/usr/local/lib/python3.13/site-packages/wyoming/event.py", line 79, in async_read_event
json_line = await reader.readline()
File "/usr/local/lib/python3.13/asyncio/streams.py", line 562, in readline
line = await self.readuntil(sep)
File "/usr/local/lib/python3.13/asyncio/streams.py", line 677, in readuntil
await self._wait_for_data('readuntil')
File "/usr/local/lib/python3.13/asyncio/streams.py", line 539, in _wait_for_data
await self._waiter
asyncio.exceptions.CancelledError
Then the piper log:
ERROR:asyncio:Task exception was never retrieved
future: <Task finished name='wyoming event handler' coro=<AsyncEventHandler.run() done, defined at /usr/local/lib/python3.11/dist-packages/wyoming/server.py:31> exception=BrokenPipeError(32, 'Broken pipe')>
File "/usr/local/lib/python3.11/dist-packages/wyoming_piper/handler.py", line 48, in handle_event
return await self._handle_event(event)
File "/usr/local/lib/python3.11/dist-packages/wyoming_piper/handler.py", line 114, in _handle_event
await self.write_event(
File "/usr/local/lib/python3.11/dist-packages/wyoming/server.py", line 29, in write_event
await async_write_event(event, self.writer)
File "/usr/local/lib/python3.11/dist-packages/wyoming/event.py", line 131, in async_write_event
await writer.drain()
File "/usr/lib/python3.11/asyncio/streams.py", line 378, in drain
await self._protocol._drain_helper()
File "/usr/lib/python3.11/asyncio/streams.py", line 167, in _drain_helper
raise ConnectionResetError('Connection lost')
ConnectionResetError: Connection lost
File "/usr/local/lib/python3.11/dist-packages/wyoming/server.py", line 41, in run
if not (await self.handle_event(event)):
File "/usr/local/lib/python3.11/dist-packages/wyoming_piper/handler.py", line 50, in handle_event
File "/usr/lib/python3.11/asyncio/streams.py", line 366, in drain
raise exc
File "/usr/lib/python3.11/asyncio/selector_events.py", line 1057, in write
n = self._sock.send(data)
BrokenPipeError: [Errno 32] Broken pipe
And the whisper log:
INFO:faster_whisper:Processing audio with duration 00:03.070
INFO:wyoming_faster_whisper.handler: What is the weather?
