Issue with HTU21D on alternative i2c connection
I’m using HASS version 0.81.1
Not succeeding to have sensor working.
HTU21D sensor not detected in bus 0
2:22 AM components/sensor/htu21d.py (ERROR)
Bad reading: 5
2:22 AM /srv/homeassistant/lib/python3.5/site-packages/i2csense/init.py (ERROR)
I even created a complete new clean build.
(sudo) i2cdetect -y 0 shows sensor at x40 !
In fact i’m using pins 28/29 to connect my sensor, having a ZigBee board using my first range of pins.
I tried a lot of solutions, including different entries in config.txt…
  • platform: htu21d
    i2c_bus: 0
    i2c_address: 0x40
    in configuration.yaml
Any help/suggestions welcome
Similar issue here, but not on an alternative bus. After upgrading Home Assistant on a Raspberry Pi 3 B+ from 0.75.3 to 0.83.3 my HTU21D sensor is no longer detected. Any help will be much appreciated. Thank you.
See below for details.
home-assistant.log
2018-12-11 13:56:58 ERROR (SyncWorker_9) [homeassistant.components.sensor.htu21d] Bad reading: 5
2018-12-11 13:56:58 ERROR (MainThread) [homeassistant.components.sensor.htu21d] HTU21D sensor not detected in bus 1
configuration.yaml
GPIO attached HTU21D Temp/Humidity sensor
  • platform: htu21d
Generic Thermostat…
climate:
  • platform: generic_thermostat
    name: Apartment 1 Thermostat
    heater: switch.apartment_1_heat
    target_sensor: sensor.temp_humidity_temperature
    min_temp: 70
    max_temp: 75
    target_temp: 72
    cold_tolerance: 1
    hot_tolerance: 1
    min_cycle_duration:
    seconds: 3
    keep_alive:
    minutes: 3
    initial_operation_mode: “auto”
    Generic
    away_temp: 65
i2cdetect -y 1
40: 40
ls -l /dev/i2c*
crw-rw---- 1 root i2c 89, 1 Dec 11 01:17 /dev/i2c-1
dmesg | grep i2c
[ 5.336012] i2c /dev entries driver
./HTU21D_test
22.08C
22.61%rh
I’m having the exact same issue as you, and getting the exact same errors.
Did you manage to solve it somehow?
