Issue with IKEA BILRESA wheel type not working properly
Hello everyone,
I have the device connected to an IKEA hub, which I use to turn the new IKEA Matter over Thread lamps on and off. The IKEA hub is connected via Thread integration in my Home Assistant.
My problem is that it simply turns off or goes into hibernation and no longer works, the leds in the device dont turn on when I press any button, or works with a huge delay. Any tips?
Experiencing the same problem. Interestingly enough, the remote works properly with IKEA app, so it seems like the delay happens somewhere between the IKEA hub and homeassistant.
Seems like known issue with HA:
I have this same issue. However, if I have the Home Assistant mobile app open and on the remote’s device page, it works perfectly.
Imdeed, it works for me too as long as I’m on the remote’s device page in the app or webpage… strange. Perhaps, this needs to be added to the issue description, so hopefully someone will find the cause and fix it.
Same problem here with both myggspray and bilresa scroll wheel. They seam tp go on a sleep mode. some times they work some other times they don’t.
Interestingly, the bilresa dual button works fine on HA.
I have 2 Myggspray and both work if the device page is open as someone stated.
The Bilresa scroll wheel most times does not work on HA but it does work nice via Ikea integration.
Is anyone working on this?
This is fixed in the latest IKEA update 2.934.5
Is it? After updating my Dirigera to 2.934.5 it seemed to work briefly but over night I’m facing the same issue again.
Does it work reliably for you?
Strange. It does work for me, no issues at all now, so using several Bilresa after the fix. The issue has been closed too after many users confirmed the fix.
You are right. False alarm. It seems to work now. The place where I kept the Bilresa had some reception issues. After changing the location it now works as it should :+1:
