Monarch Money defaults to showing a “Current Balance” which is off by well over $100 making this integration absolutely useless to me… however. Their web ui has an option titled “Use available balance instead of current balance” which does show the correct balance i need! However the problem is that the integrastion still shows the “Current” balance despite the fact that in the UI I have the “Available” option checked… any ideas on how to fix this? I REALLY want to use this integration.
Hello. Is the Monarch integration working? It used to work. But now it requests a MFA code, but I don’t have MFA at Monarch turned on.
I couldn’t find anywhere to ask about this so i stuck it here.
If Monarch is a dead integration or not being supported, it should be removed from HACS.
Any information would be helpful.
Thanks.
Kevin
It appears this MFA Monarch issue is still occurring - 5 months later. Does anyone still work on this integration?
