Issue with Nodon SIN-4-RS-20 Module: "Up" Command Greyed Out in Home Assistant (ZHA)
Hi everyone,
I’m experiencing an issue with the Nodon SIN-4-RS-20 Zigbee module that I’ve installed to control my electric roller shutter. I’m using Home Assistant with ZHA and a Sonoff Zigbee 3.0 USB Dongle Plus E as my coordinator.
Here’s what’s working:
  • The physical buttons connected to the module work perfectly: I can control the shutter up and down with no issues.
  • I was able to pair the module successfully with ZHA.
Here’s the problem:
  • In Home Assistant, after pairing, I can only use the down and stop commands from the UI.
  • The up command is greyed out and not usable.
  • Additionally, there’s an option to invert the commands in the module settings, and when I use it, the “down” command actually raises the shutter. However, the “up” command remains greyed out regardless of inversion.
I’ve tried re-pairing the device and checking the logs, but didn’t find any obvious errors. Has anyone encountered a similar issue with this module in ZHA? Any ideas on how to get full control (up/down/stop) working from the Home Assistant interface?
Thanks in advance!
