Hey all ,
Im having a strange issue, i combined the relay and scene sector sketch and everything works well the buttons trigger and the scene and i can control the relay. The only problem is that when i control the relay ( In home Assistant ) it also activates the scene
I have attached my sketch and home assistant automation
Any help would be greatly appreciated
Sketch
// Override Setting for Manual Node ID to 2
#define MY_NODE_ID 15
// Enable debug prints to serial monitor
#define MY_DEBUG
// Enable and select radio type attached
#define MY_RADIO_NRF24
// Enable repeater functionality for this node
#define MY_REPEATER_FEATURE
#include <SPI.h>
#include <MySensors.h>
#include <Keypad.h>
#define RELAY_1 3 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
#define NUMBER_OF_RELAYS 2 // Total number of attached relays: 4
// Opto Relay Module I was using Active Low - Low (0):ON, High (1): OFF
#define RELAY_ON 0 // GPIO value to write to turn on attached relay
#define RELAY_OFF 1 // GPIO value to write to turn off attached relay
#define SN “Scene Controller”
#define SV “2.0”
#define KEYPAD_CHILD_ID 95
bool initialValueSent = false;
//Init MyMessage for Each Child ID
MyMessage msg1(1, V_LIGHT);
MyMessage msg2(2, V_LIGHT);
MyMessage scene(KEYPAD_CHILD_ID, V_SCENE_ON); //scene ON
MyMessage scene2(KEYPAD_CHILD_ID, V_SCENE_OFF); //scene OFF
const byte ROWS = 4; //four rows
const byte COLS = 1; //one column
char keys[ROWS][COLS] = {
{‘1’},
{‘2’},
{‘3’},
{‘4’}
byte rowPins[ROWS] = {A3, A4, A1, A2}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {A5}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
byte lastState;
void before() {
for (int sensor=1, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS;sensor++, pin++) {
// Then set relay pins in output mode
pinMode(pin, OUTPUT);
// Set relay to last known state (using eeprom storage)
digitalWrite(pin, loadState(sensor)?RELAY_ON:RELAY_OFF);
void setup() {
void presentation()
// Send the sketch version information to the gateway and Controller
sendSketchInfo(“Relay”, “1.0”);
// Register all sensors to gw (they will be created as child devices)
present(sensor, S_LIGHT);
present(KEYPAD_CHILD_ID, S_SCENE_CONTROLLER);
keypad.addEventListener(keypadEvent);
void loop()
if (!initialValueSent) {
Serial.println(“Sending initial value”);
send(msg1.set(loadState(1)?RELAY_OFF:RELAY_ON),true);
wait(1000);
send(msg2.set(loadState(2)?RELAY_OFF:RELAY_ON),true);
wait(1000);
Serial.println(“Sending initial value: Completed”);
wait(5000);
char key = keypad.getKey();
void receive(const MyMessage &message) {
Serial.println("=============== Receive Start =======================");
if (message.isAck()) {
Serial.println(">>>>> ACK <<<<<");
Serial.println(“This is an ack from gateway”);
Serial.println("<<<<<< ACK >>>>>>");
// We only expect one type of message from controller. But we better check anyway.
if (message.type==V_LIGHT) {
Serial.println(">>>>> V_LIGHT <<<<<");
Serial.println(“Receiving initial value from controller”);
initialValueSent = true;
// Update relay state to HA
digitalWrite(message.sensor-1+RELAY_1, message.getBool()?RELAY_ON:RELAY_OFF);
switch (message.sensor) {
case 1:
Serial.print(“Incoming change for sensor 1”);
send(msg1.set(message.getBool()?RELAY_OFF:RELAY_ON));
break;
case 2:
Serial.print(“Incoming change for sensor 2”);
send(msg2.set(message.getBool()?RELAY_OFF:RELAY_ON));
break;
default:
Serial.println(“Default Case: Receiving Other Sensor Child ID”);
break;
// Store state in Arduino eeprom
saveState(message.sensor, message.getBool());
Serial.print(“Saved State for sensor: “);
Serial.print( message.sensor);
Serial.print(”, New status: “);
Serial.println(message.getBool());
Serial.println(”<<<<<< V_LIGHT >>>>>>”);
Serial.println("=============== Receive END =======================");
void keypadEvent(KeypadEvent key) {
switch (keypad.getState()) {
case PRESSED:
lastState = 1;
break;
case HOLD:
lastState = 2;
break;
case RELEASED:
int keyInt = key - '0'; //Quick way to convert Char to Int so it can be sent to controller
if (lastState == 2) {
//keyInt = keyInt + 4; //If button is held, add 4. If using more than 4 buttons this number will need to be changed
send(scene2.set(keyInt));
} else {
send(scene.set(keyInt));
//break;
Automation
automation:
alias: “scene selector”
trigger:- platform: state
entity_id: sensor.relay_15_95
to: ‘1’
action: - service: light.turn_off
entity_id: light.cams_room_tv
- platform: state
alias: “scence selector2”
entity_id: sensor.relay_15_95_2
to: ‘1’
action: - service: light.turn_on
entity_id: light.cams_room_TV
- platform: state
