Issue with Shelly 2.5 (MQTT) and home assistant,
Connected to home assistant using MQTT, and each x hours (randomly) the device (Shelly) is not reachable.
Login to Shelly interface web interface (using direct IP), press restart and everything start working until the next disconnect.
You need to collect some information to help you work out what is going on. Check:
- MQTT broker log
- Home Assistant og
- Shelly Status (ip_address/status)
The issue is only with the Shelly 2.5, all other devices are ok and working 100%
as i am understand many people have issue with this and some of them flush other firmware.
trying to find other solutions…
