After updating to V 2021.12.3
I can no longer turn on lights for example, If a device such as a lamp is used in an automation (I have certain lights to come on a sunset and go off at midnight), these lights I can not manually turn on, for example today is a bit dark and need to turn on the light so I go to the Lovelace and flick the switch as I would do normally, however they are showing as on from last nights automation and when turned off at midnight the switch stayed on but lights went off, now If I turn switch to off after a couple seconds will click its self to on but the light does not turn on.
Config is valid, have restarted and then the switch works, but need to do it each day.
Then in the evening if lights are off the automation triggers and turns them on however the switch stays in off position, and I am unable to manually turn off it needed, I will click the switch and it turns on and after few seconds turns off (but lights stay on).
I have rolled back to back up before update and works fine, then when I update it starts this behavior again. Any advice or should I roll back until this is fixed?
