Issue with TADO integration
After using TADO integration for some years now, I faced an issue with the integration. I cannot use the login credentials of TADO anymore in the integration. Details:
  • I believe it is happening after a restart after an update some cycles ago. Not sure which one;
  • My Tado app works well with the credentials used. So the credentials are correct
  • When being prompted to enter the PW, the correct user name is indicated
  • After entering the PW, I get ‘unknown error’
  • Restarting or reinstalling the integration does not resolve the issue.
So, what to do?
Thanks for your suggestions
FYI. Same here ;(
here is the solution: Tado Integration Not Working Since Daylight Savings Time Change · Issue #141961 · home-assistant/core · GitHub
