currently I am running:
# docker exec -it hassio_cli ha core info
arch: amd64
audio_input: None
audio_output: None
boot: true
image: ghcr.io/home-assistant/qemux86-64-homeassistant
ip_address: 172.30.32.1
machine: qemux86-64
port: 8123
ssl: false
update_available: true
version: 2022.11.5
version_latest: 2022.12.9
watchdog: true
When I try to run any update (core, add on), it failed with this error in a log file:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/hassio/update.py:305
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 12:52:54 PM (1 occurrences)
Last logged: 12:52:54 PM
[139653532141792] Error updating Home Assistant Core Unknown error, see supervisor
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 303, in async_install
await async_update_core(self.hass, version=version, backup=backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 45, in _wrapper
raise HassioAPIError(data["message"])
homeassistant.components.hassio.handler.HassioAPIError: Unknown error, see supervisor
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 200, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1744, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1781, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 208, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 678, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 943, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 715, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 154, in async_install
await entity.async_install_with_progress(version, backup)
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 413, in async_install_with_progress
await self.async_install(version, backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 305, in async_install
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Core Unknown error, see supervisor
I am running it on top of ubuntu 18.04. Ubuntu itself seems to be healthy, I didn’t face any similar issue before.
Do you have any hints?
Thank you.
