Hi everyone,
I’ve just set-up an ESP32 C3 super mini with 2 sensors, BME680 and SGP41. I am currently having issues deploying the configuration as I keep getting this error:
Failed config
sensor.bme680_bsec: [source /config/esphome/air-quality-kitchen.yaml:28]
Component sensor.bme680_bsec requires component bme680_bsec.
platform: bme680_bsec
temperature:
name: BME680 Temperature
pressure:
humidity:
iaq:
co2_equivalent:
name: BME680 CO2 Equivalent
breath_voc_equivalent:
name: BME680 Breath VOC Equivalent
text_sensor.bme680_bsec: [source /config/esphome/air-quality-kitchen.yaml:44]
Component text_sensor.bme680_bsec requires component bme680_bsec.
iaq_accuracy:
name: BME680 IAQ Accuracy
This is odd to me as from the reading I have done on this forum it indicated that the library for the bsec part should work and is supported. Thus I am not sure what I have done wrong.
This is my yaml configuration:
esphome:
friendly_name: Air_Quality_Kitchen
esp32:
board: esp32-c3-devkitm-1
framework:
type: arduino
# Configuration entry for ESP32
i2c:
sda: 8
scl: 9
scan: true
# Configuration for SGP41 TVOC Sensor
- platform: sgp4x
voc:
name: "Kitchen VOC Index"
nox:
name: "Kitchen NOx Index"
# Configuration for bme680_bsec Sensor
- platform: bme680_bsec
temperature:
name: "BME680 Temperature"
pressure:
name: "BME680 Pressure"
humidity:
name: "BME680 Humidity"
iaq:
co2_equivalent:
name: "BME680 CO2 Equivalent"
name: "BME680 Breath VOC Equivalent"
text_sensor:
iaq_accuracy:
name: "BME680 IAQ Accuracy"
name: "BME680 IAQ Classification"
icon: "mdi:checkbox-marked-circle-outline"
lambda: |-
if ( int(id(iaq).state) <= 50) {
return {"Excellent"};
else if (int(id(iaq).state) >= 51 && int(id(iaq).state) <= 100) {
return {"Good"};
else if (int(id(iaq).state) >= 101 && int(id(iaq).state) <= 150) {
return {"Lightly polluted"};
else if (int(id(iaq).state) >= 151 && int(id(iaq).state) <= 200) {
return {"Moderately polluted"};
else if (int(id(iaq).state) >= 201 && int(id(iaq).state) <= 250) {
return {"Heavily polluted"};
else if (int(id(iaq).state) >= 251 && int(id(iaq).state) <= 350) {
return {"Severely polluted"};
else if (int(id(iaq).state) >= 351) {
return {"Extremely polluted"};
else {
return {"error"};
I would greatly appreciate any help.
