Issue with VS Code add-on
Dear all,
first, I wish all here a happy new with all the good luck and best wishes.
After recognizing that IDE9 was depracated I shifted to the VS Code add-on. Just today after a reboot of the box I checked the logs for issues and found the following.
In the hass.io system log I got multiple of these:
20-01-08 09:14:17 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_vscode
20-01-08 09:14:17 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
20-01-08 09:14:17 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
In the add-on log itself:
2020/01/08 10:14:23 [error] 484#484: *59 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-vscode, request: "GET / HTTP/1.1", upstream: "http://127.0.0.1:8443/", host: "pfitznerhome.duckdns.org", referrer: "https://pfitznerhome.duckdns.org/hassio/ingress/a0d7b954_vscode"
[08/Jan/2020:10:14:23 +0100] 502 91.41.23.36, 172.30.32.1(172.30.32.2) GET / HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36)
info  Server listening on http://127.0.0.1:8443
info    - No authentication
info    - Not serving HTTPS
The config of the VS code add-on is as follows:
  "ssl": true,
  "certfile": "fullchain.pem",
  "keyfile": "privkey.pem",
  "packages": [],
  "init_commands": [],
  "disable_telemetry": false
Despite the errors in the logs everything seems to be working fine???
What to do best to get rid of the errors?
Regards
Ralf
Don’t know exactly why, but the problem is gone :expressionless:
