Issues adding to sensor in seperate file
I am trying to split up some of my config files. I set up a new file for sensors that has a bunch of template sensors which work.When I add a new rest sensor and it fails. If I comment out the external file in the configuation.yaml file and directly add the sensor to the config, the sensor works fine. I am just trying to figure out how I can add the reset sensor to the sensors.yaml file.
This is the content of the sensors.yaml file
platform: template
sensors:
  foyer_smoke_alarm_status:
    friendly_name: "Foyer Smoke Alarm Status"
    unique_id: sensor.foyer_smoke_alarm_status
    value_template: >-
      {% if is_state("sensor.foyer_smoke_alarm_smoke", "2")%}
        Smoke
      {% elif is_state("sensor.foyer_smoke_alarm_carbon_monoxide", "2")%}
        CO
      {% elif is_state("sensor.foyer_smoke_alarm_carbon_monoxide", "5")%}
        CO_EOL
      {% elif is_state("sensor.foyer_smoke_alarm_smoke", "3")%}
        Testing
      {% elif is_state("sensor.foyer_smoke_alarm_smoke", "6") or is_state("sensor.foyer_smoke_alarm_carbon_monoxide", "6")%}
        Testing
      {% else %}
        OK
      {% endif %}
    icon_template: >-
        mdi:fire
        mdi:cloud-outline
      {% else %}
        mdi:smoke-detector
      {% endif %}
My configuration.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
#homeassistant:
# Load packages
#packages: !include_dir_named packages
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
#   base_url: example.duckdns.org:8123
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
#scene: !include scenes.yaml
sensor: !include sensors.yaml
This is the new sensor I am trying to add.
   Get OpenEVSE min/max current from RAPI
  - platform: rest
    name: "OpenEVSE RAPI $GC"
    resource: !secret OPENEVSE_REST_GET_CURRENT_CAPACITY_RANGE
    force_update: no
    authentication: basic
    username: !secret OPENEVSE_USERNAME
    password: !secret OPENEVSE_PASSWORD
    headers:
      User-Agent: Home Assistant
      Content-Type: application/json
    json_attributes: ["cmd", "ret"]
    value_template: >-
      {{- value_json.ret -}}
I believe you need to remove sensor:. You already have it in the config file.
sensor: <------ REMOVE THIS LINE
  - platform: rest
    force_update: no
    headers:
    value_template: >-
Thank you duceduc, you got me on the right track. The other problem I had was I was missing a dash in front of the irst platform and had to tab it all over.
  sensors:
      value_template: >-
          Smoke
          CO
          CO_EOL
          Testing
          Testing
        {% else %}
          OK
        {% endif %}
      icon_template: >-
          mdi:fire
          mdi:cloud-outline
        {% else %}
          mdi:smoke-detector
        {% endif %}
  # Get OpenEVSE min/max current from RAPI
- platform: rest
  force_update: no
  headers:
  value_template: >-
