I have a working Hass.io system with Samba running in a VirtualBox VM. I’m currently using Home Assistant on another machine. When I copied my configuration files from Home Assistant to the VM there were at least 2 issues. First, Im still using !include_dir_list automation/
on home assistant but the VM only found the applications in the first folder. Do I really need to migrate all my applications to a single applications.yaml file for Hass.io or am I missing something? Second, The configuration for Tuya is being ignored in Hass.io. Here it is:
I’m assuming by “applications” you mean automations? If so, as long as you have only one automation in each file with !include_dir_list it should work. What do you mean by “only found the [automations] in the first folder?”
Also, what do you mean by the tuya config being ignored? Any errors in the log?
Opps, I did mean automatons. And my automation folder has 12 sub-folders. Only those automations in the first sub-folder /alarms made it into the VM… Automations in the other 11 sub-folders didn’t show up. And I was in such a hurry to get my Home Assistant back online, I forgot to check the logs. Jeez…what was I thinking.
That’s weird about the automations subfolders. Not sure why that wouldn’t be working. Did you reload automations using the button in the frontend?
Also, just to clarify, you’re still running Home Assistant with Hass.io. Hass.io is one method of installing Home Assistant that enables additional functionality (add-on store and snapshot capability). This is a good read if you don’t understand what I mean.
I have Home Assistant running in a venv on a Ubuntu based laptop. I have Hass.io running in Vbox on different Ubuntu desktop system. I reloaded my automations with the button to no effect. Also upon closer inspection I have no scripts at all. Only the handful of applications I actually have appear in the logs. There is no mention of scripts. As far as tuya is concerned it found a couplew of lights and switches but missed others. Perhaps there’s a name problem I can check under ‘states’
The Tuya issues were all associated with names that got overwritten at some point. That issue is now fixed. Here it is I think I got rid of all the secret stuff:
homeassistant:
auth_providers:
- type: homeassistant
- type: trusted_networks
trusted_networks:
- addr/24
- 127.0.0.1
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: lat
longitude:long
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 1118
# metric for Metric, imperial for Imperial
unit_system: imperial
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: America/Chicago
customize: !include customize.yaml
namecheapdns:
domain: home.com
password: !secret namecheap_password
#speedtestdotnet:
# server_id: 16142
# scan_interval:
# minutes: 15
# monitored_conditions:
# - ping
# - download
# - upload
lovelace:
mode: yaml
tplink:
discovery: true
media_player:
- platform: vlc
camera:
- platform: generic
still_image_url: http://addr
stream_source: rtsp://stuff
wink:
# Show links to resources in log and frontend
#introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
# enable nmap presence detection
device_tracker:
# - platform: nmap_tracer
# hosts: addr.120-124
# home_interval: 15
- platform: ping
hosts:
list
#custom_updater:
#component_urls:
# - https://raw.githubusercontent.com/robmarkcole/Hue-sensors-HASS/master/custom_updater.json
notify:
- name: notify
platform: pushbullet
api_key: !secret notify_api_key
- name: sms
platform: smtp
server: smtp.gmail.com
port: 587
timeout: 15
sender: [email protected]
username: [email protected]
password: !secret bdtgmail_password
recipient: [email protected]
# Discover some devices automatically
discovery:
ignore:
- directv
# - wink
api:
cloud:
alexa:
filter:
include_entities:
- input_boolean.my_bedtime
- input_boolean.wakeup
- input_boolean.bark
- input_boolean.dinner_ready
- input_boolean.wegone
- input_boolean.nap_time
include_domains:
- switch
- light
- fan
exclude_entities:
- input_boolean.barking_enable
- input_boolean.hue_switch
- input_boolean.dim_bedroom_enable
- input_boolean.double_door_button
- input_boolean.double_garage_door
- input_boolean.double_garage_door_alarm
- input_boolean.in_alarm
- input_boolean.pbx_srvr
- input_boolean.livingroom_lights
- input_boolean.misters_on
- input_boolean.nightlighting
- input_boolean.sunrise_enabled
- input_boolean.testing
- input_boolean.answer_door
- input_boolean.master_bedroom_lights
exclude_domains:
- automation
- device_tracker
#http:
# api_password: long stuff base_
system_health:
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# scene descriptions
# scenes: !include scenes.yaml
# Enables support for tracking state changes over time
history:
recorder:
# View all events in a logbook
logbook:
hue:
bridges:
- host: addr
allow_unreachable: true
# filename: phue.conf
tuya:
password: !secret tuya_password
country_code: 1
platform: smart_life
python_script:
logger:
default: error
logs:
homeassistant.components.python_script: debug
homeassistant.components: info
homeassistant.components.device_tracker: critical
homeassistant.components.camera: critical
# Track the sun
sun:
sensor: !include sensors.yaml
ambient_station:
api_key: stuff
app_key: more stuff
red_conditions:
script: !include_dir_merge_named scripts/
switch: !include switch.yaml
light: !include lights.yaml
input_boolean: !include input_boolean.yaml
envisalink: !include envisalink.yaml
zwave:
usb_path: /dev/ttyACM0
polling_interval: 30000
autoheal: False
# Text to speech
tts:
- platform: google_translate
service_name: google_say
# service_name: google_say
ring:
username: '[email protected]'
password: !secret ring_password
binary_sensor: !include binary_sensors.yaml
climate:
group: !include groups.yaml
shell_command: !include shell_commands
mqtt:
broker: 192.168.1.17
port: 1883
keepalive: 60
client_id: sbmqtt
username: name
password: !secret mqtt_password
mqtt_statestream:
base_topic: bark
include:
domains:
- input_boolean
automation: !include_dir_list automation/
