The above picture is from the MQTT broker that i installed… it is from the configure portion of the integration.
I tried that lastnight and still nothing… the ONLY thing i found online and youtube that i dont think i have done is adding the login and password to the mqtt configuration page within the integration.
ill keep that in mind if i ever get this up and working.
Within console of the device, it does show that it has the home assistant setup as seen below:
Im also seeing this in the integration log
Little more messing around and looks like it discovered the device
thank you all for the suggestions and guidance, at this moment, i cant really say which made the difference, but thank you all…
I do leave the tasmoadmin addon running but I don’t login.
Hi, I have the same issue on HA 2022.10.1 native on RPI3.
If I click on TasmoAdimin in the sidebar the browser try to connect to https://xyz.duckdns.org/tasmoadmin but fails. If I connect directly to https://xyz.duckdns.org:9541 it works fine.
In my configuration.yaml the panel_iframe is set to:
tasmoadmin:
title: TasmoAdmin
icon: mdi:power-socket-eu
url: https://xyz.duckdns.org:9541
How can I fix it?
Thanx
Your Home Assistant needs to be on ssl as well. You can’t run https iframe if HA is only http
SSL is active and working
