Issue's setting Zwave up
Hey Guys,
I am having some issues with setting zwave up. I have a z-stick gen5 and 2 Hank door/windows sensors. Home assistant is installed on a RP3B using hassio.
I added zwave to my config:
zwave:
usb_path: /dev/ttyAMA0
I tied adding the sensor using the stick unplugged, it pairs but doesn’t show in the HA dashboard.
When I click add Node on the zwave page nothing happens. The light on the stick keeps switching colors like always. The sensor doesn’t link.
Does anyone know what the problem is?
Some Z-Wave controllers, like Aeotec ZW090 Z-Stick Gen5, have ability to add devices to the network using their own contol buttons. This method should be avoided as it is prone to errors. Devices added to the Z-Wave network using this method may not function well.
From Z-Wave - Home Assistant
Fixed it. I did use the normal zwave setup guide instead of the hassio one.
